anyone who has installed gt500 pumps...
alexthejew
Jewish and lovin it.
ok, so i have got everything else wired up. but i cant seem to figure out where this goes. any help?
07gt6816
im trying to remember correctly but im sure that connector should go to the connector that is coming from your stock harness
chuck@evoperform
Boss surgeon
Official Vendor
Delaware
Do not use the connector that was provided with the kit. Cut the end you have there off, and cut the wires from the factory harness, and solder them together. If you don't, you most likely will have problems with your fuel guage.
alexthejew
turned the key to acc, and the fuel gauge was perfect. just wired it backwards like i was told to on other threads. tried to crank the car, and it felt like there was no fuel pressure. it cranked and almost turned over once, but no luck. any ideas?
JoshK
Modder AKA Fuel
Nebraska
I didn't have to replace any fuses when I installed mine. Can someone please elaborate. ..
alexthejew
in the fuse box underneath the hood, there is a fuel pump fuse that you are supposed to (i believe) replace with a bigger amperage fuse.
alexthejew
got it i think lol. i forgot to put the fuse in to the new power connector. DURRRR
Figured it was something like that, so you got i tall working now?
To Fuel, you need to replace your stock fuel pump fuse under hood with a larger fuse or it will blow. Stock is 15amp and you need to put a 30amp in there.
alexthejew
You also need a 30 in the new positive side connector, or is a 15 fine there?
JoshK
Modder AKA Fuel
Nebraska
Is this the fuse that you are talking about. . . I don't have a manual in my car so I don't know which one you are talking about
The fuse that is in the wire that comes with the fuel pump kit is already a 30.
alexthejew
The blue one at the bottom right of what you're pointing at needs to be replaced with a 30 and a 30 goes in that positive wire connector
