Are 05-09 and 11-14 H&R Race springs the same?
Speedboosted
Found missing cylinders
PNW
Talked to H&R today on the phone and the desk jockey that answered had no idea about any of the products. All I need to know is if the 05-09 H&R Race Springs are the same design as the 11-14 ones they make. They're staying on my 2006, but I'm going to be using the 11-14 struts and camber plates.
It seems that a lot of other spring manufactures make the same springs for all S197's. I'm aware that there can be slight differences in spring rates based on it being a coupe/convertible and which engine is up front, but none of that matters for me since that isn't changing. This probably sounds like a dumb question, but are the springs the same shape? All the guy could tell me was that the springs I have only are for 05-09, but what about the 2010? They use the same style struts and mounts as the earlier years do.
Thanks for any input!
I am Legend
McKinney TX
Essentially all the springs from 05-14 will work on any s197. Even though part numbers are split to match the break between early/late s197s. Obviously there may be some slight changes in spring rate (if any) depending on the manufacturer of the spring.
Speedboosted
PNW
Thanks again Jon.
