Autometer, AEM, PLX, and Zietronix gauges ?
09CandyredGT
Zimmers Fab turbo kit is going on my car right now and I am starting to look for gauges. I am looking for a wideband and boost gauges. My question is on the wideband. Autometer widebands I notice only read 0-4v for data logging. I was told I need to get one of the other gauges listed because I need to have 0-5v so I can read the wider range. Is this true? Also what gauges would be you suggest I get?
JoshK
Modder AKA Fuel
Nebraska
I like my Innovate Motorsports LC-1 wideband. It has fully programable analog outputs. I run the DB blue gauge with the wideband and a cobalt digital blue boost/vac gauge. Both of these gauges are wired into my firewire cable also so I can datalog af and boost.
You may want to consider using a EBoost 2 for you boost gauge and boost controller all in one though.
Fake_Snake
FAUX GT500
Houston, Tx
i have dm-100's 3 of them with boost, af, and iAt ( i had an early type thermocoupler ) so it wouldnt read correctly so i tossed it.. there pretty sweet gauges but im actually wanting something simpler to just use if your intrested in any of them let me know..
09CandyredGT
Fuel, I dont know which gauge it is from innovate but I have had several people tell me that they are bad for burning out sensors. Have you had any issues?
TurboX
Formally Buzz Lightyear
San Anto,Tejas
I personally use PLX because they interface with my iPad thats integrated into my dash. I use to use a AEM and have used innovative before.
Don't they all use the same Bosch sensor ?
HellsBells
620/677
SoCal
I'm going to echo Fuel on this one.
I have an LC-1 with a DB Gauge (although mine is red so it's obviously better than his). I've had the gauge and original sensor for 3 years on a daily driver. I then switched cars and the sensor was thrown into storage for about a year.
I reinstalled the gauge and sensor into my Mustang in November last year, the sensor was dead (probably because it got beat up in my toolbox for a year, getting knocked around and all). The replacement sensor was $80, it's a standard bosch sensor for a Volkswagen. Still going strong now.
I've also had the AEM gauge before and I can tell you that, although the sensor is the same, the LC-1 updates much more frequently. The result is that the numbers on your gauge will change quicker and give you quicker readings.
Here's a video of the gauge on my previous car and how quickly it responds (on the left obviously. Note that the newer DB gauges now say "INNOVATE MOTORSPORT" on them. I have the ones when they were first released):
I can't speak for other kits other than the AEM because I haven't had any. But my AEM gauge was sluggish compared to this one.
09CandyredGT
I will check more into the Innovate gauges also. Never knew trying to pick gauges would a hard choice
