Dubstep Shep
WUB WUB VROOM VROOM
Recently I upgraded to stainless steel lines on all four corners. Bought the kit from American Muscle because the lines came with OEM like mounting brackets and were a straight swap.
Long story short, the new lines weren't as thick as the OEM lines where they connect to the caliper. I found that out the hard way. Because of this my banjo bolts were acting as set screws on my rear caliper pistons.
I had to cut an eighth of an inch off the end of my banjo bolts to get everything back correctly.
My advice: measure the thickness of the new lines before you out them on, and take the difference off of your banjo bolts.
