Best choice for 05-09 Tie Rod End
Gab
Bullitthead
My initial response was going to be Motorcraft, but I see that you've been through several OEM parts. Is/was your car slammed? I'm surprised that OEM parts haven't lasted for you.
o2sys
NY/NJ
I've had OEM, then Whiteline which made so much noise had to lubricate them every month and now I'm using Autozone lifetime replacements which 1 month into it ripped the boot and grease leaked all over.
I'm also looking for a "better" replacement and might give Moog a try.
mfergel
Richmond, VA
Roush stage 1 springs. Only 1 1/2" drop with them. Guess I'll try the Motorcraft one more time.
hamish
B.C.
Steeda used to make a nice bump steer kit
bujeezus
Alabama
I went with the OPR in your first post after my factory passenger side took a dump. Only about 5k miles on them but no issues. I liked the fact that you don't have to lubricate them and the boot seemed to be a better piece than stock.
skwerl
tree hugger
central Florida
Moog is always my first choice. Back in 1988 I bought my first new vehicle, an F150. By 30K miles it had the dreaded 'death wobble'. Replaced the garbage OEM tie rod ends (pressed together with a piece of rubber between the ball and cap) with Moog. The Moog ones were still good when I traded the truck in with 210K miles.
travelers
Eastern Pa
We use these (ball joints and tie rod ends) on the race car because of they get extended each time it's raced because of pulling the wheels off the ground and coming back down.
http://proforged.com/
RocketcarX
95% of my weight is fuel
Colorado
Moog is the best parts store product you'll get without going to NAPA's much more expensive premium line.
