Best Limited-Slip Differential
NUTCASE
Try car-part.com and put your location in for the search. You can also try newtakeoff.com.
The stock gear on the 2005-10 was 3.31. A 3.55 was optional but I don't think that it was available on the 4.0
I am pretty sure stock 8.8s can be found with 3.06, 3.31, and 3.55 (my car had 3.55 stock). However I have seen them for sale with 3.73, 4.10, 4.30, and 4.56 already installed.
its not any every day find, but they can be found. especially since people swap to either a 9 inch or a pre built 8.8 often.
cbass
Rochester, NY
^^ For that price, plus the install kit, plus the labor to get it set right... you're better off buying a used 8.8
Speedboosted
Found missing cylinders
PNW
Indeed. Way better off getting a used 8.8. Hell, even an old worn out one can be refreshened for like $150 total. Grab an old one for $400, rebuild the clutches for $100, swap pinion flange ($25), replace pinion nut with motive seal kit ($30), and be on your way.
