Big stuff 3 ignition?
strong_j
TX^SWAG
Wylie, tx
What is everybody using for ignition boxes?? Preferably under 500 bucks.
I've ordered it and all the gm sensors I need I think.
strong_j
TX^SWAG
Wylie, tx
Nevermind. Tuner was trying to get me to go with the mmr Distributor route. But it looks very costly.
CPRsm
Not really a point in ditching the COP's until they can't keep it.
IMO, unless you r building a pure race car, the stock ECM and ignition is fine.
strong_j
TX^SWAG
Wylie, tx
Well I'm gunning for low 9's. So I'm trying to get everything I need. Alot of my turbo foxbody friends run a big stuff. So I plan on a big stuff and also the traction control module (etm).
The Foxes don't have the sophisticated PCM like ours. There are cars in the 8s on stock PCM.
If u r more comfortable with BS3, it's your $$
86GT351
Sunny South Florida
That is the key. Tuning fo the new style ECM has come a long way since the Fox Days!
strong_j
TX^SWAG
Wylie, tx
I have the ETM option also, which driveshaft speed sensor are you using?
I haven't bought the sensor yet. I literally just ordered it. I have a whole list of things to do before I tackle the little details.
What sensor do u use??
jeostang
Maryland
Have not ordered that part yet, that part of the harness in just sitting behind the console, only using the 3 step, oil pressure, and Fuel pressure right now.
05stroker
Never enough power guy!
Bullard Tx.
Agreed. I will however be doing some testing with the MSD Dis4 setup on my car with the stock computer and the MSD coils after tuning is done. I am on the stock pcm with the MSD coils now and all has been good with a gap of .032 up to 24 psi with no blowout. I plan to test the Dis4 setup at .032 and then .040 and see what happens.
GB10
8s coming soon?
Burleson, TX
Your best bet with BS3 is to use LS coils if your BS3 will support it. Much easier and less expensive and you can make plenty of power.
strong_j
TX^SWAG
Wylie, tx
That's what I did. I did the bs3 with ls1 coils from jpc racing. Also dea and dai.
silverpoison
SoCal
Im using bs3 with ls coils, not a single problem, we have 7 cars deep in the 8's using them as well.
