The Foxes don't have the sophisticated PCM like ours. There are cars in the 8s on stock PCM.
If u r more comfortable with BS3, it's your $$
I have the ETM option also, which driveshaft speed sensor are you using?
IMO, unless you r building a pure race car, the stock ECM and ignition is fine.
Your best bet with BS3 is to use LS coils if your BS3 will support it. Much easier and less expensive and you can make plenty of power.What is everybody using for ignition boxes?? Preferably under 500 bucks.
I've ordered it and all the gm sensors I need I think.
