Blowfish Racing Shifter Support Kit
skwerl
tree hugger
central Florida
It fits the MT-82, not the TR3650. Ford designed the external shifter to mount to the transmission at the front and to the car body at the rear. There are bushings to allow the shifter to move so it doesn't bind up when the engine and transmission rotate slightly from torque.
The Blowfish bracket removes the rear shifter mount bolted to the car body and makes a rigid mount completely supported off the back of the transmission. This is similar to other transmissions where the shifter is built into the case and is not attached to the car body.
bullitt boy
NJ
I have one in a box pm me its yours for $175 + shipping. It was on my 2014 for about a month. I had no issues with it and found it really did work. I wanted to try the new MGW and the blowfish bracket does not play well with that piece.
:thud:
they do make one for the 3650
https://www.blowfishracing.com/drivetrain/107-2005-2010-mustang-gt-tr3650-shifter-support-kit.html
as far as how it works... the company tells you......
KEY FEATURES:
-PATENTED DESIGN MODIFIES SEMI-REMOTE MOUNT SHIFTER CONFIGURATION TO BE DIRECTLY MOUNTED TO THE TRANSMISSION
-REAR CLAMP DESIGN UTILIZES AN ISOLATION MOUNT TO ELIMINATE NOISE
-IMPROVES SHIFT ACCURACY DRASTICALLY ON THE STOCK SHIFTER
-PREVENTS HIGH RPM LOCKOUT
-PROLONGS SYNCHRO LIFE
-INTEGRATED NHRA LEGAL DRIVESHAFT SAFETY LOOP FOR ADDED SAFETY
-INTEGRATED DUAL PUCK ISOLATED TRANSMISSION MOUNT
-INSTALLS WITH BASIC HAND TOOLS IN ABOUT 2 HOURS
-FIRST RELEASE ONLY WORKS WITH FACTORY SHIFTERS. AFTERMARKET SHIFTER VERSIONS COMING SOON
