Blue Ice
W1ldcat
St. Joseph Mi.
Is it worth putting stuff like that or the other brand in the Intercooler
reservoir? I put a bottle in the radiator and couldn't really tell. I didn't do any real test to tell though and in MI the weather changes all the time.
Thanks,
jk
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
I don't have a water gauge but I bought the same type of stuff from Wal Mart; it's green, comes in 16 oz vice the 12 oz Red Line Water Wetter from Advance and is only $6.88 a bottle. When I compared the specs on the back they were the same.
It works best with 100% water for intercooler systems. Instead of raising the boiling point like coolant it keeps the water to around 200-205 so it cant boil. If you going to use it in the radiator with coolant it isnt going to have any effect really on a 50/50 setup your gonna want 25% coolant 75% water and 1-2 oz per quart of WATER in the sytem, That way coolant can still do its job and the water with wetter will remove heat better.
W1ldcat
St. Joseph Mi.
Red line was what I was trying to think of. I'm going to add a bottle to the intercooler and see if I can see any diffrence on the intake air. Red line has no anti-freeze properities and my little tank is full so I'll ruin my wife's trukey baseter and remove enough to add a bottlle and come winter maybe pull some out of the tank and add antifreeze if the hydometer doesn't show it not being good enough to not freeze. I doubt it, but not worth freezing the core. Unless I was sure it was the one by the raditor,and that would be a good reason to buy the Afco. Just kidding.
