Boost a Pump help
kyoshosp2
Baton Rouge, LA
Well since im almost maxing out the stock pump i orderd a bandaid for now. but it has no instructions for a 2011 gt. I tried calling KB but they never answer the phone. So does anyone know where i tap the pump into on the driver?? i called some shops but no luck there either,
Kingcrabb
Cecil County, MD
If its anything like the boosta pump for the Focus u just need to find which wire is the power to the pump, cut it, and run the KB in line with it. It has to be AFTER the factory fuel pump control box. On the focus it was a green and orange wire.
SD07GT
people are making 525 rwhp with the stock pump how are you maxing it out (LOL)
Twinscrewgt
Bad Smurf
Ogden, Utah
http://mustangforums.com/forum/2005-2011-mustangs/441593-kenne-bell-boost-a-pump-install-w-pics.html
mine ended up being the big purple wire you need to splice..
SlowA$$5.0
Banned
USA
they are 7psi stock and me and my tuner were stuck at mid 550 range then we discovered they sent a 3.8 pulley instead of a 3.5.. that should get me 600 and the intake i heard cough cough will allow me to go to 7800 and another 45-60 rwhp above the factory.. heck i still have stock airbox and manifolds lol ,, right now beats 2.9 whipple gt500s lol
Monty is your tuner?
I assume you are on stock internals correct? If you rev 660 rwhp to 7800 rpm I do believe you pre-qualify for this thread: http://www.s197forum.com/forum/showthread.php?t=54322
