quiksilver15
I have an extra connector for the cruise if you are interested in buying one!
Which connector? The harness from the factory steering wheel?
Actually just saw this earlier. I think you need some type of module to get the radio controls to work.
Anyone have the music controls working for a Shaker 500? I have the two connectors but I have no idea wtf I'm doing.
Evidently a interface can be built to work on aftermarket HU.
That is correct, I have it working on my buddy's car. We used the PAC audio SWC adapter into an aftermarket HU. Just followed the directions for the 2010+ Mustangs and it all worked fine.
Those are the same directions I used. I did not see anywhere that state's to ground anything besides the pac itself. Am I missing something.
Thanks.
Sent from my EVO using Tapatalk 4
Connect the INTERFACE's White wire to Pin 18 (Gray/Yellow) of the vehicle connector. Connect Pin 19 (Brown/Green) to chassis ground. Cut the Purple loop then connect a 100 ohm resistor to the second Purple wire, cap off the first (outside edge) Purple wire. Connect other end of resistor to the White wire.
The green wire in the steering wheel is under the same pin as the torx screw on the wheel. That is grounded. So you are saying I need to tie that into the wpt on another wire and ground that? Makes no sense, a ground in the wheel is the same as a ground elsewhere.
My wpt has only one wire connected on either side. Purple on the wheel and the the same pin on the clock spring going to the pac.
Thank you for your help.
