one.wicked.stang
Grudge Race?
Ive reached the limits on the stock block. Im at the point its a gamble every time I get on it to possibly blow the motor.
This winter I plan on building a motor.
The only 2 things in/on the motor are hotrod cams and a Whipple HO kit (3.25 pulley). The Whipple will transfer over, the cams Im undecided on. Ive also got LTs, o/r H, 60# injectors, Ford Racing TB. Auto trans with TCI servos, hardened input shaft and PI 3500 stall. Those will swap over as well.
Im clueless on what rotating assembly kit or short block to get.
Motor is still good so I could pull and get it cleaned all up or just buy a complete short block.. I figure the cost to prep the block and install the kit if I go that route will probably be close to short block costs. This is why I am thinking of just buying a short block but from who??.
I search a few vendors here and read horror stories from all of them.
I want to turn the car into strictly a race car.
Ive even contemplated selling/trading my car outright and buying a fox body race car that someone else has built.
Buying a shortblock looks to be in the 4500 up range plus the cost of heads.
Im probably looking at 6-7k for everything?
Ive got a friend who races and he mentioned a month or so ago that this would be a hard decision to make because of costs and it is.
In the 1/8th Im very low 7s and in the 1/4 low 11s. Its fast, just not fast enough...
So, any thoughts? This is hard..
If I build whose a reputable builder/vendor to buy from?
298 stroker?
302? stroker?
If I decide to build will the car be faster or same times? Last thing I want to do is put that much money into it and be the same times. Granted the engine will be a hell of a lot stronger..
Sorry for the rambling on, and thanks for any input...
298 stroker?
302? stroker?
