Built 4R70, PI converter, Quick 4 controller and more
Status
Not open for further replies.
JST4FN
Tyler,Tx
Up for sale is a low mileage 4R70W with PI torque converter and Hayden 679 trans cooler. Mileage is around 3000, more than likely less as I've had my motor out twice while it was installed. It was a fresh build (when purchased) using ATF Speeds Stage 4 kit. It has a upgraded stub shaft and TCI pan. I had Dan at Silver Fox Racing build me a constant pressure valvebody. The shifts are great, but converter lockup can be harsh depending on when you lock it. It's like a shift, on or off there is no slip feel. I found my car worked better only locking in 4th at 53 mph. This made it very streetable for me. Also please note that this has the *1 1/2 longer tailshaft. The converter is a Precision Industries single disk lockup with a 3600 stall speed. This is not a stock replacement trans as is. It's more for high HP cars or street strip duty. $2000 plus shipping
Other parts used for S197 install:
US Shift Quick 4 controller w/harness -$500 plus shipping(harness will need to be lengthened or shortened for your application)
Ford Racing M4602G Driveshaft -$250 plus shipping
Steeda Cobra driveshaft spacer - $40 plus shipping
Lokar flexible dipstick - $75 plus shipping
B&M Pro Rachet shifter - $125 plus shipping (does not include cover and the front cover mount is cut off)( the handle is painted gray with a black painted knob)
I have all the receipts on the trans parts, converter and valvebody. I also have the instructions for the Quick 4. All prices are negotiable
Thanks Mike
JST4FN
Tyler,Tx
I'm currently waiting on a deposit to arrive. Because of that I haven't marked it sale pending or sold yet. I will put you in line in case something happens.
Thanks Mike
Status
