C&L Racer Intake
07shelbyGT
Raeford, NC
The intake is used bought from a member here and then used by me. The nipple for the vent tube is broken off, but you can either plug it or use a larger tube and fit it over the rest of the vent tube, this is what I did. Anyhow its in good condition.
$100 shipped
07shelbyGT
Raeford, NC
Skarkull
I just removed the factory nipple, and cut the C&L nipple off right from where it goes from skinny to fat, drilled it out, and installed the factory with a little silicone. Allows you to use the factory tube.
07shelbyGT
Raeford, NC
yeah I just ran large enough hose to fit over it and clamped it down and clamped it on the other side, worked just like normal.
06Torch
Houston, TX
If you're real picky about the way it looks; you could cut off the C&L nipple from the vent tube, buy a grommet of a suitable size, place it in the C&L, and shove the factory nipple from your OEM intake in it. That would certainly look a lot better than using silicone. The guys at AutoZone don't care if you open a couple of packages from their HELP section.
Gerardo
