CAI on kennebell stage2
kepsus
Hi , does anyone know if i can buy a CAI to my mustang gt with kenne bell stage 2, that one they come with the kit looks like .....
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Easy to make, if you can cut intake pipe!
Here's what I used to make that:
- a 4" 45* polished pipe, with 3" cut off one end (that's the end that goes up against the KB TB adapter)
- another 45* 4" pipe, with 7-1/4" cut from one end and 3-1/2" from the other end; the longer end goes down to the maf housing. (I later cut off another 2")
- coupled to the first cut pipe with a 4" hump hose near the water reservoir; coupled on the bottom end to the maf with a straight 4" coupler
My BEC and PCM are completely out of the way.
kepsus
wow that looks so nice..
Would you be able to sell one ?? :-D
TexasBlownV8
Central Texas
Exactly like that, yeah I could put a kit together...but it might not fit your setup.
Like I said, my BEC and PCM are NOT where KB has you relocate them to. This pipe setup could interfere with the standard BEC relocation.
:hi:
kepsus
right now i have a catch/oil bretaher tank, but would like to make it "standard", the pcm are moved like used to in the Kenne bell Kit.
Is the maf located like "normal" kb setup
TexasBlownV8
Central Texas
The maf is close to where KB has you put it. I actually lowered mine by 2", using a flat metal brace connected to the ma housing and body, so that the maf connector was not hitting anything and could be disconnected easily.
So, the length of the pipe going down through the front is about 2" longer than what most people would have.
kepsus
ok i was looking to put the maf , closer to the TP. I have some problem when i am in speed that it make some strange value on maf, when i only put a very small amount on throttle on it.
I was hoping it could help if i move it a Little.
If you drive "fast" and take clutch and slip throttle.. does it die , or go very unstable, until the car have reach lower speed.
