Canton Oil Pan
retfr8flyr
The Old One
Providence Forge, VA
I have a Canton Oil Pan for the Modular engine. It was drilled for my twin turbos and has a plug installed on each side at the front, from when I went to water only Comp turbos. Other then the plugs it is in very good condition. The plugs don't effect anything but when I went back to oil cooled turbos I didn't want to try and remove the plugs and re-install drain lines so I bought a new pan and put new openings in it. I am asking $150 plus shipping for this pan.
In this pic you can see one plug on the far side of the pan in the front.
Very clean
retfr8flyr
The Old One
I have it with the stock tray on my car now. Canton also makes a windage tray but it requires another gasket and lowers the pan about 1/2 inch. I originally had that tray but it interfered with my 1/2 lower BMR K member when I added it. I removed the Canton tray and went back to stock.
