so long story short my full bolt on, nsr cammed GT had an engine mishap. Racing a buddy in mexico and it just started to mis fire really bad but didn't really make any noise. got it back to the shop and pulled the heads off the car and found one broken exhaust valve. the valve stayed in the head so luckily it didn't hurt the bottom end.
just finished putting comp valve springs/retainers in the car and it ran fine for several days before this. i did bump the limiter in the race but didn't think anything of it (7200). it broke the guide off the head where the valve seal goes over.
im really shocked that this happened and my buddy said it is most likely a defect in the valve and see no reason why it broke. like i said it was a clean break and the stem itself looks good. the follower stayed in place and the follower/cam appear to be undamaged.
several well known shops told me to shift@ 7k and set the limiter @ 7200. So im really confused as to why this happened.
i plan on getting some used heads with stainless valves and a valve job and putting it all back together with 2v iron tensioners instead of the plastic ones.
thoughts? comments?
thoughts? comments?
