Got a issue that i can not find. It will do it sometimes and then it won't. Put the car in say 3rd and go wide open on the throttle and you can feel the rear of the car lift a little and try to steer to the left. 1st and 2nd you can feel it but 3rd is longer so you can really feel the movement. 4th and 5th gear you don't notice it that bad due to lack of power. I figured it was maby a bad bushing in one of the control arms, so i have replaced all with new bmr upper,upper mount,lowers,panhard,new pan hard brace,new rear end upper bushing on the housing,new rear shocks. Car still did the same thing after replacing everything. I have had the car on the lift,everything looks good and straight and aligned. Even checked lower control arm body mounts and such. Also while on a lift, pulled on the suspension and such,no movement. Only thing i have not changed or checked is the posi unit. From a dead stop the car will still leave 2 marks. My question is yes it may leave 2 marks,but wonder if it is locking and unlocking at say a higher speed causing it to track. It is a factory unit with around 90,000 on it. Has anyone run into a issue similar to this. Any suggestions is welcomed.
