Car will start, but shuts off immediately. Fail safe mode
Deathstang II
I'd check the actual TB Actuator plug. When I had to remove my Intake plenum and plug back in the actuator the fuckin red retainer that's suppose to keep the plug from backing off somehow got jammed into the plug and broke. Thus causing it not to properly be plugged in, gave me similar codes. Ended up just forcing the plug off, breaking that red retainer and problem solved. Sometimes stupid shit happens.
Flapjack
Lunatic engine swapper
Colorado Springs, Colorado
I can't stand how many Ford plugs can be switched. Nightmares with the CMCP motor plug, knock sensors, and something else in that area come to mind...
BAD3VLV
Houston,Texas
Don't feel bad man. I have the R2300 phase 2 kit on mine and when I pulled the motor out to fix a bent rod and broken piston, I did the exact same thing. On a stock car they wont reach, but with the supercharger you move the plugs closer together and this can happen. They look identical, so there's absolutely no way to tell without knowing the wire colors for them. You live and learn.lol
1950StangJump$
Now and again, I do something mindless and cause what I think is a big problem .... and it ends up being easy.
While I might joke about being mad over my stupidity, most of the time I'm just more relieved the problem was an easy fix.
I think that means my anxiety is bigger than my ego.
