CG Fabrication 2005 to 2009 3V forward facing turbo setup.
Codenamefa
NGL, this makes me want to redo my turbo setup on my 3v. I wouldn't use the crossover tube though, I'd have a 90 degree elbow to 90 degree t3 or t4 flange and have twins sitting in front of the motor like the coyote kit. Sure it forces me to use aftermarket radiator fans over my factory radiator fans but I'd be able to create my own turbo setup with larger turbos like G35-1050's..... And it would look actually pretty unique as no 3v really ever did that turbo setup..... Ugh.... The urge. Then the quest for 1000hp wouldn't be even a hard target to hit. GT3076r's are running out of efficiency, currently at about 28psi with the current setup. Maybe when I get a little more finances under my belt.
Current setup. offset twin turbos on up front and one in the back.
