GT500KR
ok here it goes. got a 2008 GT with a DOB S/C kit on her. having issues from day one with breaking belts...etc... but that was an issue with not having the tensioner setup right. thats the least of my issues.
got a knocking sound coming from the motor right now... well i say its coming from the new clutch i had installed recently but my transmission guy says no. so regarless im gonna pull the s/c and send it off and the tensioner to get inspected/fixed and then do a compression test and check the oil after drainging and see if i find any major problems before i pull the trans.
my question with the trans is ive done plenty of work on v8 s10s and fox bodys and such. anything tricky about pulling a trans on a s197??
pretty sure something broke on the clutch... and it gets louder right after you turn the key off.
heres some pics of where im at now...
start off with... after it sitting in storage till i could have time and room to work on it i took it out for a casual drive to get my bearing on what the car was or wasnt doing... this after i trailered it down to my trans guy the 2nd time... 3 hours away. got 3-4 miles away to a stop sign and heard a terrible noise... got out and found this
the newer idler was coming off the bearing and into my S/C alt bracket...
great!!! called my bro to bring my truck and trailer down
so after getting her home she sat on the trailer for 2 weeks
then when i got time and room in the garage i gave her a wash
then i put the lower side scoops on
so then i replaced the failed idler with a metco one
everything seemed fine. thought id take her into town and get oil and a compression tester for her to help diagnose the knock noise before i pull the trans to inspect the clutch...
i no sooner get into the autozone parking lot and hear some bad noises under the hood and see my S/C pulley rolling down the parking lot!
dunno how it did it but the belt stayed on the blower shaft
heres some before pics of the belt misalignment before the trip to autozone. think the blower moved on me? i dunno. gotta investigate more.
