GlassTop09
On using an 11-14 OEM UCA (or aftermarket version dimension-wise), I had the exact same idea initially as well due to the extra 1" of length reducing the amount of pinion pitching\deflection during vertical suspension travel.........until I read Billy Johnson's posting on the Roush 3rd Link UCA's design\performance aspects about 4 yrs back (a Jack Roush modified OEM Ford 05-10 GT\07-09 GT500 UCA assembly) thus I bought 1...........little did I realize that mine would be 1 of the last ones Roush produced\sold before discontinuing these, but this piece paired w\ this 13-14 GT500 UCA diff bushing is a match made in heaven for any street\strip performance S197........especially when also paired w\ the same 13-14 OEM GT500 LCA's.This is the one I would use if doing this job today. I might also consider using the upper control arm and mount from the 11-12 GT to take advantage of the longer length arm.
At OEM Bullitt ride heights (I'm sitting on 08-09 OEM Ford Bullitt front\rear take-off springs) & geometry, wheel hop is non-existent.......even on 6,000 RPM WOT clutch dumps, the pinion hardly deflects at all.......just enough to not shock the tires (Conti Extreme Contact DWS06 in 295\35\18 on 07-09 OEM Ford GT500 18"x 9.5" wheels thus also on GT500 designed offset & contact patching) so hard on initial clutch engagement so that they lose all resemblance of traction thus traction recovers very quickly w\o lifting & rear end tracks straight (due to the 13-14 GT500 LCA's) thus stays properly behind the chassis........thus allows the full TQ output use of this 4.6L NA V8 w\o any TQ modulation applied while easily maintaining control of the chassis.
The old adage applies............"spinning ain't winning".
To top my setup off, I'm waiting on my set of Maximum Motorsports S197 rear LCA relocation brackets to get here (they're the only manuf that makes these to work w\ the OEM Ford-designed S197 rear axle LCA's) so that I can up the anti-squat to around 74% (the 1st hole down from stock).......this should tighten up my car's launches\corner exit acceleration to the hilt w\o breaking traction but still retain\maintain full OEM rear axle ride & articulation thus control.........making the perfect street performer\driver's car.
Well.........this is my long-winded way of saying I agree w\ everything you've stated...........I think you'll love the improvements if\when you do it.
