paydirt
Roll Racer
Well,
Recently got my car back from it's 2nd built motor endeavor...used the same place who did the first one though I had my doubts...got the car back and now I'm having a hell of a time getting it in gear. While the car was in the shop I had a big brake kit installed and when I got the car back the pedal felt real spongy...like there was air in the line. I also like I said could barley get it in gear. Me and the shop both thought this was because there was still air in the brakes lines which shares the reservoir with the master cylinder, thats why the clutch wasn't disengaging all the way. Well it turns out the brembo 8 piston calipers have two bleeder screws on the top and the shop was only bleeding one. After they bleed the brakes properly, the brake pedal felt great! but the clutch is still fucked.
My question is what do you think might be causing this? They say they know the clutch is installed properly but I guarantee they didn't check. There is pedal pressure like there always is but its not dissengaging all the way.
Could it be a bad slave cylinder? or a bad TOB? The clutch is a mcleod rst with only 4,000 miles on it. I never do hardcore burnouts or anything. Please give me some insight guys.
Thanks,
Ryan
Thanks,
Ryan
