Gruca
World's Slowest 3v Owner
So I was getting off the expressway the other day and was in 2nd gear. I merged over and floored it and when I went to shift in to 3rd, it wouldn't go in. I rolled to the stop light and could not get the car in to any gear. I finally forced it in to first and, with the clutch pedal to the floor, the car wanted to move forward on its own. I managed to get it to the train parking lot. When I got back from work, the shifting was a little easier, but progressively got worse as I drove. I made it home and the brake fluid was really low, so I topped it off. It drove around much better, but was still a little harder than usual to shift and reverse was still REALLY hard to get in to. The minute I got the rpms higher, the car became extremely hard to shift again. When I try to use the clutch pedal, it grinds and hard to shift. When I am actually moving and not shifting, you can't even tell anything is wrong...until I have to shift. If I just skip using the clutch pedal altogether, I can shift it fairly easily (at the right RPMs of course).
I'm trying to figure out if this is a clutch master cylinder issue or if I need to replace the entire clutch/pressure plate assembly.
Thanks!
Thanks!
