Combined 15" wheel Fitment Thread
Enitalp
The lost guy.
Canada, QC
After 06, ford used 3 different company to make the caliper of the mustang, they all use the same pad, but the capiler size is not the same. So it's not because an after 06 works that the others will. They all are the same part number.
Sources : Mustang Source (KC) & AllFordMutang.
Due to Component Shortages Ford is Using 3 vendors to Manufacture the 06 Brake Calipers. Due to Production Variances the calipers have Different Design Tolerances. So wheels that Barely fit on one Car may not clear on another. This could also cause a problem in the Future IF the 05 caliper Part Number Superceeds to an 06 Part Number
Be advised the 06-10 Base & Gt Models all use the Same Caliper Part Numbers. So if you have an 05 and Update the Calipers you may have the Fitiment Problems Associated with a Wheel designed to clear the 05 Calipers. That is Marginal Fit with 05 Calipers become Interference when Using 06 up Calipers. Also if you Purchase Some Used or Old Stock Wheels Designed for the 05 you could have the Same Issues on a 06-10.
Hawgman
THE fucking bad guy
Texas
Just a quick update to the Holeshot wheels that XtremeStang posted above. Holeshot no longer welds the spacers to the wheels. They said they had problems with discoloration. They now bolt them to the wheel for $10 a piece.
xtweakerx
Get SOME!
Palm Beach, FL
so its a complete gamble if wheels will fit on the 07+'s.. lol
i guess if u get it and it dont fit for some odd reason start the modifying!!:angry1:
xtweakerx
Get SOME!
Palm Beach, FL
Holeshot Holestars for 2007 197 stock GT brakes
Fronts 15x4 with 7/8" spacer total BS 1 7/8"
Rears 15x10 with 7/8" spacer total BS 7 7/8"
You can have Holeshot Wheels weld the spacers on like Bogarts.
No need to change studs, wheels come with McGard long shank lugs/open end.
did you have to modify anything to get them to fit on the 07? Like grinding or anything or just the spacers did it ?
Hawgman
THE fucking bad guy
Texas
where do you buy the holeshots from?
One of our sponsors, Blow By Racing, has them and currently has a special going on. Check their vendor forum in the vendor section on this board for details.
You can also use the dealer locater link from Holeshot's webpage
xtweakerx
Get SOME!
Palm Beach, FL
blow by says on their site you have to like cut some tab off the rear sway bar to fit the rear 15 inch rim?
Dex
I'm Dexolishous
Utah
With your mods/hp you could get away with a 15x8 rim that fits and costs a lot less.
Hawgman
THE fucking bad guy
Texas
Not unusual. Pretty much any 15X10 you are going to have to either cut the tab off the mounting piece for the sway bar, or get sway bar relocation brackets, or delete the sway bar all together.
xtweakerx
Get SOME!
Palm Beach, FL
i think when i get some cash ill go with the JEGS SPORT STAR CAST WHEELS for my setup. But i have to figure out what size and tire to mount up front and out back. I want to do M/T's on all 4 most likely, e.t streets out back.
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
just look at the tire lists on summit/jegs wherever they will tell you what tire can be run on what wheel
fullpullprez
I know for the et streets (not the radial but the bias ply) some run a 26x11.5x15 in the rear. This is what I'm gonna run...
