so i got a customer of mine manage to completely destroy the rear end on his Track-Pack 2013 GT500..
it needs a new ring and pinion, torsen diff and both rear axle shafts..
pretty much everything has a tooth or two missing (and in the ring gear's case, most teeth!)
so the only thing intact will be the axle housing, which i'm thinking of welding or reinforcing (unless there's a straight forward 9" kit to swap in!)
now apart from a new differential, bearings, and strange or moser axles.. i'm thinking of getting the new ring and pinion gears cryo-treated.
any thoughts on that? any idea if anyone sells cryo-treated gears off-the shelf that's been tried and tested?
