lito
The easier way to test the wire is to feed voltage from a (AA,AAA,C, something below 5V) battery to the analog wires and see what happens.
That's why I like the LM1/LC1. Since it's programmable you can simply set it to read ONLY 2.5 volts then check to see what livelink is reading.
Ted, my wire is firewire one one side (SCT device) and 1/8" stereo on the other (LM1). What's yours like?
I have an xcal 2.. no fire wires for me. just vmp mini din.
I saw in your pic that you can read 1-3+V on the spade connector... Is the other end of the cable a six pin firewire? .
This is BULLSHIT!! I see why Joe gave up..
Got the over priced VMP cable.
-Cut female end
- found out sig gnd= light purple wire
- found AN1 = green wire
- put a connector on both and crimp and heat shrink
- smoked and drank
- hooked everything up
- set livelink an output to just read V
