dataloging help!
calispecial08
Ok so I started the car for the first time today since the s/c install and I was going to datalog with Lito but I can't seem to get my livelink to work. I had livelink 6.3 so I went ahead and updated it to 6.5 to see if it helped and it didn't.
The problem is when I click the "begin datalog" button it says "Handheld Device Initialization Failed!"
I have checked the USB connections and the OBDII port connection and everything is fine, i have restarted it and everything and can't seem to get this figured out!
Anyone have any ideas???
Thanks,
Eric
gt08vapor
Turn the computer off. Have everything hooked up. Then turn the computer on. Evertime I would unhook rebook anything this is what I would have to do
Also lito is great.
calispecial08
Thanks a lot I will try that and see if it works!
gt08vapor
No problem . Lito remote tuned mine Friday. I have. Otho g but good things to say about him.
If live link still fails, I would uninstall it the. Reinstall it
calispecial08
like the firmware or what? hasn't been updated since I got the tuner which was like 2 years ago
calispecial08
Also lito is great.
Bump! Tried this and it didn't help!
Any other ideas??
JoshK
Modder AKA Fuel
Nebraska
Does your sct device power up when it is hook to the computer only?
JoshK
Modder AKA Fuel
Nebraska
Does the sct device ever say "CAN activated" or something like that when you are all hooked up to everything...
JoshK
Modder AKA Fuel
Nebraska
yes
Also, did lito send you a configuration file to open in livelink? You are opening the config file and not the tune, correct?
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Are you seeing this screen?
calispecial08
yes
It never says that, that I am aware of. Yes I am opening the configuration file in livelink with the key on and then I start the car and press begin datalog button and after a second it says device initialization failed.
JoshK
Modder AKA Fuel
Nebraska
I always hook everything up then open livelink. Open livelink config and when it asks to connect to vechicle ecu, then I turn the key on and click okay. The screen should change on your sct device if everything is communicating properly.
calispecial08
I will video it when I get home, I will try it the way that you said first
calispecial08
Yeah he only sent two files and the tune has my name in it so I'm sure I'm using the right config file.
