Swine
- Joined
- Jul 31, 2013
- Posts
- 130
- Reaction score
- 1
I recently removed my OEM front sway bar to install a BMR. I noticed when removing the OEM bushings that the bushings were glued to the sway bar. In the past, on previous cars, i have always greased the bushings.
As i understood it, the sway bar needed to be able to rotate inside the bushing for proper performance. What gives? Wouldnt glued bushings add static spring rate and reduce "speed bump" performance? Perhaps the OEM bushing is supposed to rotate in the mount, as apposed to the bar rotating in the bushing?
