I need one!
Yes you do!
I need one!
Very nice! Congrats. Most of the photos I've seen for these are not as revealing to how much room there really is. Is there enough to get the trans out on a short trans jack?
I could have had one of the first electric two posts lift for free. Work was upgrading, thru out 5 Baer B52 lifts. iIRC. Did not have a place to store it. Should have made space.After my Dad closed his Ford dealership back in '07 it quickly became clear that I would miss the after hours access to the two-post hoists, the commercial grade air system and the tire machine & balancer.
I wish I could swing those for my barn.
I think this is the lift that you should absolutely never raise without a few hundred lbs on it. Something I read elsewhere in the last couple of days.
Norm
For anything over $1500, I'd go with one of these.
https://www.bestbuyautoequipment.com/nationwide-car-storage-lift-parking-lift-8000-lb-p/nw-4-8k.htm
Still portable, and it's more of a mid-rise lift as far as the tower height is concerned (I also use it with used Hunter 4W alignment system I got pretty cheap).
I used it to raise about halfway up in a normal height garage before I moved and
built pole barn. Comes with one jack tray to get one set of wheels in the air.
Later on could get cross jack if desired or just another jack tray to get all 4 wheels
up for the rare wheel rotation or maybe 4 wheels bleed.
Very useful for doing exhausts or chassis mods that need to fit right or be tightened with full weight on chassis, stuff almost impossible to do with "2 post" type lift.
Best part is drive on for quick 2 minute oil change. Takes longer for me usually to set up arms on my 2 post, than it does to do full oil change on 4 post.
Norm
The installation manual requires you to go through several lift and lower cycles with nothing at all on it to purge air and balance the systemI think this is the lift that you should absolutely never raise without a few hundred lbs on it. Something I read elsewhere in the last couple of days.
Norm
I would have loved to get a 2 or 4 post lift but my garage floor can't be drilled into to support the bolts. Obviously this is the way to go but in my case this is a pretty good option.
I have 3, 4 posts (one I bought strictly to get another parking spot in my house garage, which was built with 11 foot ceilings for some reason) and none of them are bolted down.
My most recent is an ultra tall, ultra long, 9000 lb I got so I can get my 3/4 ton diesel with cap underneath on a lift finally (and put one of my classics up there when not using lift, but still fit that 3/4 ton under it). That one is not bolted down either. It's not really required, in fact most of them come with wheel/caster kits so that you can move them around when you need to.
I have looked at those portable things for track use, but they seem kind of heavy to be able to get out of my truck. I did tow to the roadcourse last time, so possibly in the future I could find one of them lighter. I only need to lift about 3000 lbs.
One more pick of my first 8K 4post in my old house. This is std height garage. Pic is an 08 mazda6, about as high as it could go.
Oh, and here is caster kit. When lift is lowered all the way, arm pivots on wheel and raises up towers about an inch. I'm only 150lbs, and I can move it around by myself pretty easy.
