irishpwr46
Official Site Vandal
really sucks to see that. it does look like a couple sleeves will save the block though. also, what does section 9 refer to?
Sucks on the motor....part of racing. Glad the diaper did its job!!
On a bright note.....The car is leaving the line AWESOME!! The new suspension is really doing what it is supposed to. Good work on the set-up!!
On the launch for sure....so smooth.thank God the diaper held the oil. Could have been horribly worse.
Damn dude sorry to see. Any idea on the reason for the oil pressure loss on that cyl yet, all the top rod bearings look ok, too? No detonation but if the bearings are hammered, especially a larger bearing surface I could see. I have an autopsy coming up myself. Hopefully the root is easy to find.
I have talked to a lot of people and this oil pressure drop after a run while you pull the chute and brake is common. Most simply put the car in neutral and shut off the car. I never did that as I thought that would eventually burn up the trans.
