EVAP System Delete
Scott88
VA
My 2005 S197 turned 20 this year, so no more emissions tests (even though the engine is a 2018). Normally, I wouldn't mind keeping the EVAP system in since it may help the earth last a little bit longer; however, my car is getting forced into "limp-mode" or "conservative-mode" after 10-20 minutes of driving. From my research online, it looks like this will happen when there is a pressure build-up on the EVAP system, but the EVAP Purge Solenoid near the intake of the engine is stuck shut. When I did the Coyote swap, I took the EVAP system from the 2018 donor vic. I tried to make it work with the 2005 body harness, but don't have a lot of confidence that part is correct.
So I think the most foolproof (emphasis on fool) way forward is to delete the EVAP canister and purge valve solenoid, install a rollover-safe vent valve on the gas tank, and then trick the ECU to never put the car into limp-mode. The ECU is from the FPP engine control pack sold by PBH.
I can figure out how to delete the canister and purge valve, and install the rollover-safe vent valve on the gas tank. However, does anyone know how to get the computer to not put the engine in limp-mode when it doesn't see the EVAP canister or solenoid?
Evap issues cannot cause the car to go into limp mode. (Wrench light) Impossible.
You have another problem
Scott88
VA
Update: Juice was right, it was not the EVAP system. The other code that I didn't mention because I thought it was purposely part of the tune was a high idle code. This caused us to put a smoke machine on the intake manifold. Those are plastic on the Gen 3s, and sure enough, it had 4-5 hairline fractures - probably from the accident of the donor car. I didn't think it was related, because that code would be present at idle BEFORE it would go into limp mode. However, a friend of mine told me that some codes won't put the engine in limp mode right away, but after the 3rd or 4th time getting the same code, it will put the car in limp mode.
I swapped the intake manifold and no more limp mode!
