F150 Ecoboost Builds
Department Of Boost
Alpha Geek
I like the 6 spoke matte/dark gray OEM rims and you usually see them with tires which makes it cheaper/one stop shopping.
It's been a while since I looked at those stock wheels/tires. They were MAD expensive last time I looked. Maybe the price has come down.
And I've never looked for stock looking type wheels either. Only "Monster Truck" stuff, which is usually pretty cheap. I paid $120/rim for mine. They're 15x10's though. Not 20's.
GTAmuscle
Colorado
Greg is getting a hell of a deal
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
Tri-Folding Tonneau and a Bedliner....
Does anyone have a Tri-Folding and did not use the drain tubes with it and did not have issue? I usually use them when it's a Line-X, but considering not using them.
With the bedrug I'm about to put in my F-350, I do not want to cut the material to feed the tubes and not sure if there is enough slack to run them behind the liner. Just thinking if I can just get away without any drain tubes.
FYI these are the tubes I'm talking about
Mach2burnout
05 Redfire GT
Central Louisiana
You should have enough to run behind the liner. If not, run to Lowes plumbing dept. and get some longer tubing.
Sent from iPhone
GallopingFord
Northern Virginia
Gotcha. After I posted that, I looked online to see what the other guys were doing and it seems like they rigged up some stuff. I siliconed the holes next to the tailgate on the last couple demos I had just because it was a cleaner look and 4 water tubes was overkill IMO.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Received the 20's and they looks great on the magnetic, thanks for the kick ass deal!
Greg Hazlett
Official Vendor
Chesapeake, VA
Sent them to you, can you post them? I am not on taptalk or whatever the mobile thing is lol.
ford20
White Plains,NY
Those look nice on there Greg, match almost perfectly! Are you going to dip them black or something like you mentioned earlier?
If I was going to keep my truck I would grab a pair of the Fuel trophy wheels.
Shotokan1509
CT
That's the combo I was looking at when considered going new, looks awesome
I dig those wheels. Why ditching your fx4? dailying the Laguna this winter :insane:
AR Stang
Arkansas
Those are the wheels I want for my jeep, but with the color flipped. Black ring, and gray center. I may pick them up next spring with a more aggressive tire than what I have now.
Greg Hazlett
Official Vendor
Chesapeake, VA
I am going to keep them the same color, thought about black but the matte grey really looks good on the magnetic.
Greg Hazlett
Official Vendor
Chesapeake, VA
Stock height, susp mods are the fox 2.0 shocks and the Hellwig RSB.
Hankook 275/55/20 tires.
