Assuming the weather holds. Should be temps in the 60s so decent DA of around 5000' give or take.
The car is pretty much ready. Just need to go test out my line lock and practice some burnouts the day before. Have never really done any as I've always been mindful of minimizing wear on the stock clutch for when it really counts. I'm sure I'll be nervous out there. Been a long time since I've made a pass.
I will be borrowing my friend's M&H 275/50/17 (27.5") drag radials. 4.10 gearing. Due to altitude should be around 390-420whp if not heat soaked. My plan is to try a short burnout in first just to clean the tires off and warm them up a little bit. Then try slipping it from about 4500-5K.
Any suggestions on how much pressure to start with in the tires?
