jay320bird
Early this spring my timing chain hopped a couple teeth and valves made contact with the pistions. The only thing that I could find a fault in was that the timing chain tensioner on the drivers side could be compressed with your fingers and the passenger side was soild. Anyways it was a perfect time to upgrade the motor.
Eagle 298 stroker kit
BBR stage 2 cams
vct lock outs
upgraded springs
port work on heads
7 qt oil pan
TR6060 trans
SS trim twin disc spec clutch
60 lb injectors
MDM jr
fore twin pump fuel hat
fore fuel rails
inovaters west balancer
fluidyne radiator
GT500 oil pump
To go along with my 61 mm turbo from HP performance. I am hoping the get around the 650 RWHP mark just don't know if the Turbo is big enough to achieve this.
Front of Motor
Side of Motor
Clutch
Motor Trans
Will start installing tonight and will continue to update.
BBR stage 2 cams
vct lock outs
upgraded springs
port work on heads
7 qt oil pan
TR6060 trans
60 lb injectors
MDM jr
fore fuel rails
fluidyne radiator
GT500 oil pump
Front of Motor
![motorfront.jpg](/proxy.php?image=http%3A%2F%2Fi301.photobucket.com%2Falbums%2Fnn46%2Fjay320bird%2Fmotorfront.jpg&hash=5fed0b0a5870dfbc5a321f4eeacdfb93)
Side of Motor
![Motor.jpg](/proxy.php?image=http%3A%2F%2Fi301.photobucket.com%2Falbums%2Fnn46%2Fjay320bird%2FMotor.jpg&hash=b779fce07219d12271fc2f15b2d4f7b6)
Clutch
![clutch.jpg](/proxy.php?image=http%3A%2F%2Fi301.photobucket.com%2Falbums%2Fnn46%2Fjay320bird%2Fclutch.jpg&hash=4802ced1abe341094fb64d381e3c3c4a)
Motor Trans
![motortrans.jpg](/proxy.php?image=http%3A%2F%2Fi301.photobucket.com%2Falbums%2Fnn46%2Fjay320bird%2Fmotortrans.jpg&hash=c2330f34359733bdf056cacd3f4f7ae4)
