Renesis07
I somehow missed these posts when I was looking on tapatalk, sorry about that.
Yea I'll definitely be monitoring air pressure this time around, last time I didn't even check them. I was just running the car more or less practicing and getting familiar with things.
I wasn't sure about the catless and running esp, however I plan to switch to a catted setup soon anyways, so by next season I should be okay.
That's great I can just run on Sunday, I will be there!
Thanks for the tips!
I think I found your push. More air pressure in the back tires will loosen the car up as well, that may be the best play here.
I'm not much of a coach, but like I said I will help however I can. You can ride with us, too. My wife is the better shoe, ride with her.
Not sure with those mods....with no cats, you really aren't legal for esp I don't think. I would keep running in R....nobody will care until you start winning.
Yep, you can run just Sunday.....or tell your boss![]()
Not all street tires are created equal, figure you'd be 2 seconds faster on Hankook RS3s. No need to buy them yet, although your staggered setup is contributing to your understeer.
More negative camber, a bigger rear bar, and more tire pressure can all reduce understeer.
So can reduced entry speed, reduced steering angle, and reduced throttle.
A more experienced driver in your car can give you feedback about how much is car vs driver.
