Jun 22, 2025 #1 C Cavan1 Junior Member Joined Jun 22, 2025 Posts 3 Reaction score 0 Location United States I realized the other day that I have these small cracks in my spare tire well. How should I go about fixing this should I weld it or would sealant work too?
Jun 22, 2025 #3 C Cavan1 Junior Member Joined Jun 22, 2025 Posts 3 Reaction score 0 Location United States Keeps saying that the file is too big
Jun 22, 2025 #4 C Cavan1 Junior Member Joined Jun 22, 2025 Posts 3 Reaction score 0 Location United States Finally go it to up load
Jun 22, 2025 #5 MrBhp Senior Member Joined Sep 12, 2013 Posts 1,778 Reaction score 1,500 Seam sealer covered with a good body tape.
Jun 22, 2025 #6 MrBhp Senior Member Joined Sep 12, 2013 Posts 1,778 Reaction score 1,500 Best to clean the outside area very well and apply it there, as well.
Jun 23, 2025 #7 whitmanink Member Joined Dec 28, 2020 Posts 592 Reaction score 258 Location denver pa i drilled a hole in mine fo my battery vent tube,, i thank used rtv to seal up the hole, u can weld it, sealant is the path of least resistance
Jun 24, 2025 #8 A Autokyrios Member Joined Aug 15, 2024 Posts 290 Reaction score 110 Location VA, USA I'm assuming you don't have a welding opportunity. If you did, that'd be a straightforward repair. Outside of that, as others have mentioned, seam sealer, weld putty or bondo.
