Fog Light Help
TristenRamos
Pasadena
I went to turn off my car after parking it. The car turned off fine, except for the fog lights. I know I’m supposed to pull a fuse as a possible fix, not clearly defined which fuse it is from the repair manual. I’d just like for the fog lights to go on and off when they’re supposed to.
Sounds like the fog light relay is sticking.
TristenRamos
Pasadena
Makes sense, the manual doesn’t say which on is specifically for the fog lights. How is it label inside the engine? Like is it a specific number sequence on the relay, or is it in a certain port on the relay?
TristenRamos
Pasadena
water intrusion into the smart junction box could also create a problem with the lights staying on ...
Oh dang. I didn’t think that would be an issue because I’ve had the car stored underground. I should still pull it out to check though.
