slicksilver
$10,000
Located in NC. Has been my DD to keep miles off the Mustang. Great truck, and I'd trust it to drive cross-country if I needed to. Never let me down.
2004 Ford F-150 XLT SuperCab 4-Door 6.5' Bed (Styleside)
4x4 (Mechanical Shift-on-fly) w/ 4x4 Skid Plates & Fog Lamps
4.6L 2V 281ci. SOHC V8 Engine w/ 155,6xx miles
Oxford White Clear Coat Single Tone Exterior Paint Color
Light Flint (Gray) Premium Cloth Interior.
Has the 6950lb GVW Package which includes:
Heavy Duty Suspension Package (HD Springs and Shocks / 4-Leaf)
Heavy Duty Towing Package
Super Cooling Package (Large Capacity Radiator)
Heavy Duty Aux Transmission Oil Cooler
Aux Power Steering Oil Cooler
Heavy Duty High Amp Battery
Heavy Duty 4R75W Automatic Transmission
3:73 Limited Slip 8.8" Rear Axle
17"x7.5" 5-Spoke Aluminum Rims (Silver Argent)
P265/70R17 Bridgestone Dueler A/T RH-S All Terrain OWL Tires & Spare. Installed@136k mi
Front 40/20/40 Bench Seat w/ Fold Down Center Console (8 cup holders total)
Sliding Rear Window.
Full Window Tinting on all Side Glass & Back Glass.
Full and complete service done at 137,000mi. Other items installed as well which include:
Flushed and changed Engine Coolant (Antifreeze) [Motorcraft Gold]
Changed Transmission Fluid and Filter
Changed Power Steering and Brakes Fluid
Changed Transfer Case Oil
Changed Front and Rear Axle (Differential) Oil
Replaced rear Axel Seals [Ford Original Part]
Replaced rear Drive Shaft [Ford Original Part] Complete w/ Replaceable Cross Bearings
Replaced Tires (Bridgestone Dueler AT RH-S P265/70R17 OWL)
Replaced Brake Rotors, Pads, Parking Brake Pads, and Parking Brake Cables. [Ford Original Parts]
Installed New Ford Bedliner on top of Spray in Liner. [Ford Original Part]
Installed New Plastic Bed and Tailgate Rail Caps [Ford Original Part]
Installed New Front Cowl Panels [Ford Original Part] Installed@148k mi.
Installed New Front Lower Bumper Valance Panel [Ford Original Part] Installed@154k
Replaced Oil filler cap, fuel filler neck, anti-freeze reservoir tank cap, and oil pan drain plug w/ new [Ford Original Part]
Replaced Engine Drive Belt [Ford Original Part]
Replaced one Engine Idler Pulley [Ford Original Part] Installed@150k mi
Spark Plugs replaced at 100k Miles [Autolight]
Installed New Windshield Wipers [Ford Original Part]
Installed New PVC Tube [Ford Original Part]
Installed New Divers Side Power Window(s) and Door Lock Switches [Ford Original Part]
Installed New Engine Bay Heat Shield [Ford Original Part]
Installed New Passenger Side Window Regulator [Ford Original Part]
Have New Drivers Side Seat Cover and Cushion (OVER $500.00 FOR THESE TWO ITEMS ALONE!!) They have not been installed yet and are still in the original Ford packaging. They go with truck. [Ford Original Parts]
