For those who drive a automatic on the strip .
mr.incredible
Hi every one sorry for my writing im french canadian this is why i am not
posting to often over here.
Here are my setup on my car .
Whipple 10 lbs boost
stock tune of ford racing 91 octane
gear 3.90
aluminium drive shaft
coil ont pack msd
short headers
cat back
magnaflow
and the new drags radial nitto extreme 20/35/305
whitch brings me to the question .
How should i lauch on the strip with these tires ?
last time i put the tire pressure at 20 psi
heat them till the white smoke appear
and then old the gaz and brake at 1100 rpm
wen the last yellow appear slam the gaz ..... guive me a 11.90 @ 116.9 mph
out of the box 1.79 poor track condition cause no glue .
should i raise the rpm a little more ? will it stick??
How you do your launch need advice here thanks . :hi:
Dany
Hawgman
THE fucking bad guy
Texas
It's just going to be a matter of trial and error on your part to find the "sweet spot". I would start by lowering your tire pressure. I run 18" Nittos and set them at 17psi, and probably going to start dropping them down to 16psi.
Second thing is you need to smoke them pretty good. Do your burnout at least 40mph. Some folks will say more. I am just saying "at least". And once they start smoking hold it there for a good 5 seconds.
Last, work on your launch RPM. You should be much higher than 1100. Pull in to the staging area until you light the first bulb. Brake it, bring the RPMs up almost to the point of breaking the tires loose, then lightly ease off the brake until the second bulb lights. Back on the brake, keeping the RPMs as high as possible. When you see the last amber light, side step the brake and dent the floor pan under the accelerator pedal!
Steedman07
Classified's Moderator:)
Connecticut
Just the advice I was looking for too..thanks!
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I pretty much agree with Doc, except for one detail. I don't get up on the converter until after I light both stage bulbs. I prefer to stage as shallow as I can (it helps ET), and if I try to creep in to the 2nd bulb while I have the rpms up, I roll in too deep.
Hawgman
THE fucking bad guy
Texas
I completely agree with Don. Just figured we would work on his launching first, then work on his staging.
US-1
Banned
The ShadowLands
That you can launch at all on the 20" Nitto tire is saying something. Last car I saw with those was our twin turbo Charger. Damn thing lit the tires at the hit and spun them through all four gears. Lifted at 900 feet and ran 12.55 at 79 mph.
Follow Doc's advice.
