Ford Rotunda OTC Tools - For Sale
IA_Chiefs_fan
I recently purchased 52 specialty tool kits from a dealership that closed. I finally got an inventory list put together but I haven't had a chance to price the kits. If there's something you're interested in let me know and I'll see what kind of deal I can give you. Half the kits are in this post and half are in Post #2. All kits come with the plastic red cases unless otherwise noted. Many of them have sealed workshop manuals that are specific to each kit.
I rent out the 3V Valve Spring Compressor 303-1039 and 303-1175 Timing Chain Wedge. I will also sell them for the right price.
TKIT-2008ET-FIM
Escape/Mariner/Hybrid
307-633/2
307-636
Valve Body Alignment Pins
307-634
Turbine Shaft Seal Installer
307-635
Turbine Shaft Seal Protector
307-628/1
PROTECTOR,LOW/REV PISTION SEAL
307-628/2
PROTECTOR, CENTER SUPPORT SEAL
TKIT-2008ET-FLM
Ranger, Fusion/Milan/MKZ, Focus, Escape/Mariner/Hybrid, F-150, Explorer, Mountaineer, Sport Trac, Expedition, Navigator
303-1417
2.5L
TOOL, CRANK SENSOR ALIGNMENT
303-1416
2.5L
TOOL, CRANK DAMPER HOLDING
307-637
INSTALLER, 4X4 REAR SEAL
307-638
INSTALLER, 4X2 REAR SEAL
307-639
INSTALLER, 4X2 REAR BEARING
303-1418
3.0L
COMPRESSOR, VALVE SPRING
Hem Flange Tools for TSB 01-07
Econoline, F-Series Truck (no case included)
501-078
Door Hem Flange
Includes 501-078/1 (right hand) and 501-078/2 (left hand) and 501-078/3 (plastic inserts [Bag of ten])
501-080
Door Hem Flange
Door Hem Flange Crimping Tool
TKIT-2007AC-FLM
2008 ESCAPE, MARINER, Hybrid, Focus
412-136
INSTALLER, A/C CLUTCH
412-137
PROTECTOR, A/C SHAFT
TKIT-2007AP-F
F-Super Duty 250-550
310-184
6.4L Diesel
AIR PURGE ADAPTER, FUEL SYSTEM
TKIT-2007FI-FLM
5.4L INJECTOR TEST TOOL
310-190/1
5.4L 3 Valve Engine
100ML LOW FORM BEAKER X 8
310-190/2
5.4L 3 Valve Engine
STOPPER X 8
TKIT-2006UP-FLM
2007 EXPEDITION, NAVIGATOR, F-150
205-852
BEARING RACE INSTALLER
204-608
BUSHING REMOVER
TKIT-2005D2-F
307-547/8
CVT Transmission
307-547/7
CVT Transmission
307-547/9 X 2
CVT Transmission
TKIT-2005D2-F
307-544
CVT Transmission
Transmission Fluid Pump Aligner (Includes 307-544/1, 307-544/2, 307-544/4)
307-543
307-535
CVT Transmission
307-565
CVT Transmission
TKIT-2005D3-F
Expedition, Navigator, Freestyle, Montego (no case included)
204-589
Control Arm Bushing Installer/Spacer Assembly (includes 204-589/1, 204-589/2, 204-589/3)
TKIT-2005U-F
Taurus/Taurus X/Sable, MKS, Flex, Escape/Mariner/Hybrid (no case included)
205-816
Dana 28 Rear Axle
Differential Oil Seal Protector (pair)
412-133
Climate Control System
Compressor Clutch Pulley Holding Fixture
TKIT-2004J-F
Mustang, F-150, F-Super Duty 250-550, Explorer/Mountaineer/Sport Trac, E-Series, Expedition/Navigator, Crown Victoria, Grand Marquis, Town Car, Taurus/Taurus X/Sable, Fusion/Milan/MKZ, Flex
205-086-01
Propshaft Driveshaft
Adapter for 205-086 (Bridge Assembly)
303-1040
4.6L 3V, 5.4L 3V
Cylinder Head Alignment Pins (pair)
418-F395
Restraint System
Restraint System Diagnostic Service Tool/Air Bag Simulator(pair)
310-122
Fuel System (4.6L and 5.4L 3V Engine)
Fuel Pressure Gauge Connector
TKIT-2003D-TBIRD
Thunderbird Axle Kit
205-540
Driveline
Differential Bearing Gauge
205-537
Driveline
Axle Bushing Remover
205-541
Driveline
205-539
Driveline
Rear Halfshaft Seal Installer
205-538
TKIT-2002N-DEW
205-485
Aluminum Axle Bushing, Differential Cover Subframe Mount Bushings, Nodular Axle Bushing
(INCLUDES 205-485/1, 205-485/2, 205-485/3, 205-485/4, 205-485/6 & 205-485/7)
Recall / ONP 00531
2000 Focus (no case included)
204-304
Axle Shaft
Drill Bit and Guide
T99L-1000-F
Crown Victoria/Grand Marquis, Town Car, Ranger, Mustang, F-150, Explorer/Mountaineer/Sport Trac, Expedition/Navigator, F-250, F-350, Taurus, Sable, Continental, Windstar
205-453
10.5 Inch Rear Axle
PINION RUNOUT GAUGE
303-634
4.0L SOHC
KEYLESS JACKSHAFT TOOL
412-127
HEATER HOSE DISCONNECT TOOL
205-454
10.5 Inch Rear Axle
PINION RUNOUT GAUGE PIN
303-636 & 637
2V engines
TIMING CHAIN WEDGE AND HANDLE
205-460
8.8 Inch Rear Axle
PINION THREAD PROTECTOR
307-393
AX4N AX4S
PUMP SEAL AND BEARING ASSEMBLY INSTALLER
501-052
Air Bag
ANTI-THEFT SOCKET
307-394
AX4N AX4S
PUMP SEAL AND BEARING ASSEMBLY REMOVER
501-S042
DOOR GLASS BLOCK SET(INCLUDES 501-045, 501-044 & 501-043)
T96P-1000-B
Escort, Tracer, Aspire, Probe
T96P-12A650-B
BREAKOUT BOX ADAPTER
T96P-12A650-C
T96P-50-A
AIR BAG SIMULATOR
TKIT-1996-F/FM/FLM
Mustang
308-245 (T96P-7050-A)
T45
Transmission Tube Guide
308-240 (T96P-7025-B)
T45
MAINSHAFT BEARING CUP INSTALLER/REPLACER
308-241 (T96P-7025-C)
T45
INPUT SHAFT BEARING CUP INSTALLER/REPLACER
308-243 (T96P-7025-E)
T45
Hub Removal Collett Sleeve / Transmission Synchronizer Remover
308-242 (T96P-7025-D)
T45
308-244 (T96P-7025-F)
T45
SHIFT RAIL BUSHING INSTALLER/REPLACER
308-239 (T96P-7025-A)
T45
Mainshaft/Input Shaft Bearing Cup Installer/Replacer
105-00012
AIR BAG SIMULATOR
211-327
Power Steering System
Crown Victoria/Grand Marquis, Town Car, Taurus/Taurus X/Sable, Ranger, Mustang, MKS, Fusion/Milan/MKZ, Focus, Flex, F-150, F-Super Duty 250-550, Explorer/Mountaineer/Sport Trac, E-Series, Expedition/Navigator Power Steering Vacuum Fill Tool (no case included)
T95P-1000-FH-FLMH (TKIT-1995-FH/FLMH)
Crown Victoria/Grand Marquis, Town Car, Mustang, F-150, F-Super Duty 250-550, Explorer/Mountaineer/Sport Trac, E-Series, Expedition/Navigator, Ranger, Taurus, Taurus X,Sable, Mustang, MKS, Fusion, Milan, MKZ, Flex, Escape, Mariner, Hybrid
303-518 (T95P-6701-DH)
4.6L 2V, 4.6L 4V, 5.0L, 5.4L, 5.8L, 6.8L
Crankshaft Rear Oil Seal Installer
204-186 (T95T-5638-AH)
Dana 35 IFS
Front Differential Housing Bushing Remover
303-516 (T95P-6701-BH)
303-519 (T95P-6701-EH)
2.5L, 3.0L 4V, 3.4L SHO, 4.2L, 4.6L 2V, 4.6L 4V, 5.0L, 5.4L, 5.8L, 6.8L
Crankshaft Rear Oil Seal Remover
204-187 (T95T-5638-BH)
Dana 35 IFS
Front Differential Housing Bushing Installer
204-188 (T95T-5638-CH)
Dana 35 IFS
Front Differential Housing Bushing Aligner
303-514 (T95P-6701-AH)
4.6L 2V, 4.6L 4V, 5.4L, 6.8L
Crankshaft Rear Oil Slinger Remover
303-517 (T95P-6701-CH)
Crankshaft Rear Oil Slinger Installer
TKIT-1995-FLM/LT
F-150, F-Super Duty 250-550, Expedition/Navigator
205-486
Dana 80 Rear Axle
DRIVE PINION BEARING CUP INSTALLER
205-488
Dana 80 Rear Axle
DRIVE PINION BEARING INSTALLER
205-489
Dana 80 Rear Axle
DRIVER PINION INNER BEARING REMOVER
308-421
S6-650 ZF (6 speed)
CLUTCH ALIGNMENT TOOL
205-487
Dana 80 Rear Axle
DRIVE PINION THREAD PROTECTOR
T94P-1000-FH/FLMH
Taurus/Taurus X/Sable, Ranger, MKS, Fusion/Milan/MKZ, Focus, Flex, Escape/Mariner/Hybrid, Ranger, Taurus, Taurus X, Sable, MKS
303-467 (T94P-6312-BH)
2.5L, 3.0L 4V
WATER INLET TUBE REPLACER
794P-6256-DH
CAMSHAFT DAMPER REPLACER
T949-6510-AH
VALVE STEM SEAL REMOVER
303-471 (T94P-6510-DH)
2.0L, 2.0L 16V
VALVE GUIDE INSTALLER
303-470 (T94P-6510-CH)
2.0L, 2.0L 16V, 2.5L, 3.0L 4V
VALVE STEM SEAL REPLACER
303-463 (T94P-6256-AH)
2.5L
CAMSHAFT SEAL PROTECTOR
303-464 (T94P-6256-BH)
2.5L, 2.5L OHC
CAMSHAFT SEAL REPLACER
303-456 (T94P-6312-AH1)
2.5L, 3.0L Duratec
Water Pump Pulley Plate
303-457 (T94P-6312-AH2)
2.5L, 3.0L Duratec
Water Pump Shaft Protector
303-458 (T94P-6312-AH3)
2.5L, 3.0L Duratec
Camshaft Pulley Installer
303-459 (T94P-6312-AH4)
2.5L
Water Pump Pulley Spacer
303-472 (T94P-6565-AH)
2.0L, 2.0L 16V
VALVE SPRING COMPRESSOR ADAPTER
303-462 (T94P-6136-AH)
2.5L, 2.5L OHC, 3.0L 4V, 3.4L SHO
CONNECTING ROD GUIDES (2)
308-221 (T94P-7025-BH)
MTX-75
BEARING CUP REPLACER
308-222 (T94P-7025-CH)
MTX
DIFFERENTIAL DRIVESHAFT SEAL REPLACER
308-224 (T94P-7025-EH)
MTX
PINION SPINE SOCKET (Functionally similar to 205-175)
308-225 (T94P-7025-GH)
MTX
DIFFERENTIAL BEARING CONE REPLACER
T94P-7025-FH
GEAR LEVER ALIGNING TOOL
308-223 (T94P-7025-DH)
MTX
SELECTOR SHAFT BEARING REMOVER/REPLACER
T94P-6000-AH
POWER TRAIN ALIGNMENT GUAGE
308-S217 (T94P-4451-BH)
MTX
SHIM SELECTION TOOL ADAPTER (INCLUDES BH1 & BH2)
308-216 (T94P-4451-AH)
MTX
DIAL INDICATOR MEASURING FIXTURE (WITH BOLTS) (Functionally similar to 308-194A)
307-S285 (T94P-77000-E)
CD4E
SERVO PLUG REPLACER/NEEDLE BEARING RECEIVER
T94P-77000-A1 (TKIT-1994-F&FLM/FM)
T94P-77000-N
CD4E
VALVE BODY GUIDE PIN (ONLY 1)
T94P-77000-S
CD4E
TRANSMISSION TEST PLATE
T94P-77000-J
CD4E
SPRAG REPLACER
307-S305 (T94P-77000-U)
CD4E
LUBE TUBE REPLACER SET
T94P-77000-T
CD4E
SHIM SELECTION DEPTH GAUGE
T94P-77000-V
4F20E, CD4E
END PLAY CHECKING TOOL SLEEVE
T94P-77000-K
CD4E
NEEDLE BEARING INSTALLER
T94P-77000-G
CD4E
PUMP REMOVAL BOLTS
307-291 (T94P-77000-H1)
CD4E
SHIFTER SHAFT ALIGNMENT TOOL
307-292 (T94P-77000-H2)
CD4E
SHIFTER SHAFT ALIGNER
T94P-77000-R
CD4E
PRELOAD TOOL ADAPTER/ALIGNER SET
307-304 (T94P-77000-R1)
CD4E
SHIM SELECTION PRELOAD PLATE
307-304-01 (T94P-77000-R2)
CD4E
Adapter for 307-304
307-304-02 (T94P-77000-R3)
CD4E
Adapter for 307-304
307-304-03 (T94P-77000-R4)
CD4E
Adapter for 307-304
T94P-77000-E
307-286(T94P-77000-E1)
CD4E
INSTALLER, NEEDLE BEARING REMOVER
307-287(T94P-77000-ER2)
CD4E
SERVO PLUG REMOVER, INSTALLER
T94T-6379-AH
F-Super Duty 250-550 DAMPER SERVICE SET
303-486 (T94T-6701-AH1)
7.3L Diesel (DIT)
Crankshaft Rear Wear Ring Remover
303-487 (T94T-6701-AH2)
7.3L Diesel (DIT)
Crankshaft Rear Wear Ring Guide
303-477 (T94T-6002-AH)
7.3L Diesel (DIT)
KEYSTONE PISTON RING GAUGE SET
303-493 (T94T-9395-AH)
7.3L Diesel (DIT)
FUEL/OIL/TURBO PROTECTOR CAP SET (only 1 cap missing)
303-S479 (T94T-6379-AH)
7.3L Diesel (DIT)
Crankshaft Vibration Damper Service Set (Includes 303-480 thru 303-482)
303-483 (T94T-6513-AH)
7.3L Diesel (DIT)
VALVE SRPING COMPRESSOR
TKIT-1994-FH/LTH
Windstar
309-001 (T94T-6000-AH)
3.0L 2V Vulcan, 3.8L, Exhaust System
Flexible Exhaust Pipe Holding Fixture
007-00108
4WABS DIAGNOSTIC HARNESS ADAPTER
T93L-1000-FH/LTH (TKIT-1993-FH/LTH)
T93T-2100-AH
DOOR LATCH CABLE ADJUSTMENT TOOL
T93L-77110-AH
CASE CENTER SUPPORT REMOVER/REPLACER
T92T-1175-AH
Dana 80, Dana 80 Limited Slip, Dana 80 Locking Axle
Hub Seal Replacer (no case included)
TKIT-1992
007-00052
MECS SELF-TEST ADAPTER
007-00083
TFI IV CABLE PIP ADAPTER
T92C-6000-AH
AH BREAKOUT BOX ADAPTER
TKIT-1992-FMH-FLMH
Villager
007-00053
Engine
007-00054
4F20E Transmission Control Module
007-00055
ABS Module
IA_Chiefs_fan
More tool kits...
More tool kits...
007-00081 (TKIT-1991-F/FM/FLM/LM/M)
EEC-IV MONITOR ADAPTER
007-00097 (TKIT-1991-FH/FMH,-FLMH,-LTH,-LMH,-MH)
TFI-IV DIAGNOSTIC CABLE
T91P-1000-FH/FMH
4.6L V8 engines, 10P13 and 10P15 A/C Compressors, and Rear Air Suspension
Crown Victoria/Grand Marquis, Town Car, Ranger, Mustang, Low Cab Forward, Explorer/Mountaineer/Sport Trac, E-Series, Fusion/Milan/MKZ, Escape/Mariner/Hybrid
204-164 (T90P-5995-B)
Computer Controlled Front Suspension, Conventional Front Suspension, Conventional Rear Suspension
Ride Height "D" Dimension Gauge
T90P-5310-A
AIR SPRING REMOVER
T91P-19623-BH
COMPRESSOR SEAL REPLACER
412-078 (T91L-19623-CH)
Climate Control System, FS-10, FX-10, FX15 compressor
A/C Compressor Field Coil Installer/Replacer
T91P-9550-A
THROTTLE BODY ADJUSTING WRENCH
412-079 (T91P-19623-AH)
10P 13, 10P 15C, 10P 15F
A/C Compressor Shaft Oil Seal Remover
303-384 (T91P-6701-A)
2.5L, 3.0L 4V, 3.4L SHO, 4.6L 2V, 4.6L 4V
Crankshaft Rear Main Oil Seal Installer Bolts
T90C-1000-FH/FLH/FLMH
Villager
T90C-3504-BH
YOKE LOCKNUT WRENCH
303-366 (T90P-6256-BH)
1.6L, 1.8L, 2.0L
Camshaft Oil Seal Installer/Replacer
T90C-3504-CH
YOKE PLUG TORQUE GAUGE
303-369 (T90P-6565-AH)
1.6L
VALVE SPRING COMPRESSOR SCREW SET
T90C-3504-DH
PINION BEARING REPLACER
T90P-6510-AH
T90C-3504-EH
PINION SEAL REPLACER/TORQUE ADAPTER
303-365 (T90P-6256-AH)
1.6L, 1.8L, 2.0L, 3.0L
Camshaft Oil Seal Protector
T90P-19623-AH
A/C PRESSURE TEST ADAPTER
T90P-1000-A
Ranger, Mustang, Explorer/Mountaineer/Sport Trac, Bronco II, Aerostar
310-037 (T90T-9275-A)
Fuel System
FUEL TANK LOCK RING WRENCH
T87P-7065-AR
AWD Torque Tube Axle Seal Installer
303-370 (T90T-6571-A)
4.0L SOHC, 4.0L V6, 5.4L 3V
TKIT-1990 (TKIT-1990-F/FM/FLM)
Probe, Festiva, Ranger, Bronco II, Aerostar, light trucks
007-00059
4.0L
EDIS DIAGNOSTIC HARNESS
007-00057
CONNECTOR EEC-IV MONITOR
007-00044 (TKIT-1989-F/FLM/FM/LM/LT/M)
T89P-1000-B
Ranger, Festiva, Crown Victoria/Grand Marquis, Town Car, Ranger, Mustang, Low Cab Forward, Explorer/Mountaineer/Sport Trac, E-Series
303-354 (T89P-6316-A)
2.3L OHC
CRANKSHAFT HE SENSOR POSISTIONER
412-068 (T89P-19623-H)
Climate Control, FS-10
PRESSURE TEST PLATE
412-060 (T89P-19623-C)
10PA17
412-065 (T89P-19623-E)
Climate Control System, FS-10, FX-10, FX-15 and FS-10 A/C Compressors
SHAFT SEAL REMOVER
412-066 (T89P-19623-F)
10PA17 compressor
SHAFT SEAL INSTALLER
303-356 (T89P-6634-A)
3.8L SC
Supercharger Pulley Wrench
T89T-70100-A
E40D TEST HARNESS
412-063 (T89P-19623-D)
10P 13, 10P 15C, Climate Control System, FS-10, FX-10, FX-15
HOLDING FIXTURE
007-00045
1.3L
T88C-1000-F (TKIT-1988-FESTIVA)
Festiva, Escape/Mariner/Hybrid
204-142 (T88C-5493-E)
Lower Arm Bushing Receiver Remover/Installer
308-158 (T88C-7025-F)
M5
BEARING CONE REPLACER/ Rear Countershaft Installer
T88C-77000-N
T88C-7025-E
TORQUE ADAPTER
007-00027
T88C-1000-ST (TKIT-1988-TRACER)
Taurus/Taurus X/Sable, Ranger, MKS, Fusion/Milan/MKZ, Focus, Flex, Escape/Mariner/Hybrid, Tracer, Mazda, Festiva, F-150, Explorer, Mountaineer, Sport Trac, Expidition, Navigator
205-253 (T87C-1104-A)
Conventional Front Suspension Brakes
WHEEL KNUCKLE PULLER
T87C-5493-A
DUST BOOT REPLACER
303-301 (T87C-6701-A)
1.3L, 1.6L, 1.8L
Crankshaft Rear Main Oil Seal Installer/Replacer
205-254 (T87C-1104-B)
SPACER SELECTION TOOL
T87C-5493-C
BALL JOINT ROTATING SOCKET
T87C-7025-B
308-115 (T87C-7025-A)
Manual Transaxle Non Turbo, Manual Transaxle Turbo
Transmission Turning Torque Socket
205-256 (T87C-1175-B)
Brakes, Computer Controlled Front Suspension, Conventional Front Suspension, Conventional Rear Suspension
DUST SHIELD REPLACER
T87C-6019-A
FRONT SEAL REPLACER
308-117 (T87C-7025-C)
1.3L, ATX, ATX, Front Half Shaft, Manual Transaxle
DIFFERENTIAL PLUGS (pair)
T87C-6510-A
VALVE GUIDE REMOVER/ REPLACER
T87C-2500-A
MASTER CYLINDER GAUGE
T87C-6510-B
VALVE SEAL REPLACER
788C-19623-A
A/C PRESSURE PLATE REMOVER
T87C-3504-C
303-300 (T87C-6565-A)
1.3L, 1.6L, 1.8L, 2.0L, 2.0L 8V, 2.5L, 3.0L 4V, 3.0L Villager, 3.2L SHO, 3.4L SHO
VALVE SRPING COMPRESSOR SET
T88C-19703-A, B
A/C PRESSURE TEST ADAPTERS
T88C-3504-S (TKIT-1988-FH-FLMH)
T88C-3504-AH
TORQUE GUAGE
T88C-3504-BH
T88C-3504-CH
OUTER BOX TORQUE ADAPTER
T88C-3504-EH
TEFLON RING EXPANDER
T88C-3504-FH
TEFLON RING SIZING/INSTALLING TOOL
T88C-3504-GH
OUTER RACK SEAL REPLACER
T88C-3504-HH
UPPER PINION BEARING REPLACER
211-145 (T88C-3504-KH)
Power Steering Rack
YOKE LOCKNUT WRENCH
T88C-3504-LH
YOKE LOCKNUT WRENCH
T88C-3504-MH
PINON SEAL REPLACER
T88C-3504-NH
OUTER BOX TORQUE WRENCH
T88C-3504-OH
ROCK PULLER ADAPTER
T88C-3504-AH
DUST BOOT REPLACER
T88C-5493-BH
205-274 (T88C-5493-CH)
Borg Warner
Front Wheel Hub Dust Shield Installer/Replacer
T88C-77000-C
Probe
T88C-77000-CH4
CAP SCREWS X 4
T88C-77000-CH5
CAP SCREWS X 6
T88C-77000-CH1
SHIM SELECTION GAUGE
T88C-77000-CH2
308-270 (T88C-77000-CH3)
4EAT, 4F20E, G25M-R
T88T-7025-S (TKIT-1988-F/LT/FLM)
Mazda & Ranger Transmission Kit
308-170 (T88T-7025-C)
M5OD-R1, M5OD-R2
Transmission Holding Fixture
308-177 (T88T-7034-A)
M5OD-R1
Output Shaft Rear Oil Seal Installer
308-178 (T88T-12270-A)
M5OD-R1, M5OD-R2
Transmission Rail Wrench
308-172 (T88T-7025-E)
M5OD-R1, M5OD-R2
GEAR INSTALLING SPACER
308-173 (T88T-7025-F)
Conventional Front Suspension, M5OD-R1, M5OD-R2
308-174 (T88T-7025-G)
M5OD-R1, M5OD-R2, M5R2
308-175 (T88T-7025-H)
M5R2
BALL DETENT INSTALLER
308-179 (T88T-7061-A)
M5OD-R2
COLLET HALVES (2)
308-169 (T88T-7025-B)
4EAT, 4F20E, G15M-R, M5, M5OD M5OD-R2, M5OD-R1, M5OD-R2, M5R2, T-45, T45
308-180 (T88T-7061-B)
M5OD-R1
COLLET HALVES (2)
308-171 (T88T-7025-D)
M5OD-R1, M5OD-R2
FRONT COVER REMOVING BOLT SET
308-176 (T88T-7025-J)
M5OD-R1, M5OD-R2
BEARING RACE REMOVER/REPLACER (INCLUDES J1 & J2)
T87L-1000-SH (TKIT-1987-FLMH)
307-184 (T87L-77248-AH)
4R44E/4R55E, 5R55E, A4LD
Front Pump Fluid Seal Installer
307-187 (T87P-70014-AH)
AX4N, AX4S, AXODE
AXOP END PLUG TOOL
303-303 (T87L-6571-BH)
5.0L
303-302 (T87L-6571-AH)
5.0L
Valve Stem Oil Seal Installer
T87P-4000S
Taurus/Taurus X/Sable, MKS, Fusion/Milan/MKZ, Flex
T87P-7120-A
HOLDING WRENCH
T87P-5638-A
MOUNTING BUSHING RECEIVER CUP
T87P-1244-A
NEEDLE BEARING REPLACER
T87P-5638-B
MOUNTING BUSHING REPLACER
T87P-7065-A
DRIVE SHAFT OIL SEAL REPLACER
T87P-7120-B
TRANSFER DRIVE BEARING CUP REPLACER
T87P-4850-A
DIFFFERENTIAL PINION NUT WRENCH
T87P-4205-A
LIMITED SLIP SPREADING TOOL
T87P-4020-B
BACKLASH MEASURING GAGE
308-125 (T87P-7120-D)
CD4E, CVT Transmission, E-4WD
BEARING CUP REMOVER
T87P-4616-A
PINION BEARING CUP REPLACER
T87P-4222-A
DUMMY BEARING SET
308-121 (T87P-7065-B)
MTX-75
TRANSFER OUTPUT SEAL REPLACER
308-124 (T87P-7120-C)
MTX-75
PILOT BEARING REPLACER
T87P-4850-B
DIFFERENTIAL PINION HOLDING WRENCH
T87P-4020
PINION DEPTH GAUGE (INCLUDES A1, A2 & A3)
T87T-7025-SH (TKIT-1987-FLMH/LTH)
T87T-7025-NH
PULLER COLLET
T87T-7025-OH
COLLET RETAINING RING
T87T-7025-MH
PULLER COLLET
T87T-7025-LH
T87T-7025-EH
FRONT SEAL REPLACER
308-130 (T87T-7025-DH)
S5-47 ZF (5 speed)
SHIFT RAIL NEEDLE BEARING INSTALLER
T85T-1000-A
Escape, Mariner, Hybrid, Ranger, E and F Series trucks 1985 thru latest production
308-102 (T85T-7061-A)
M5OD-R2
OVERDRIVE GEAR BEARING REPLACER/OVERDRIVE GEAR SLEEVE
308-104 (T85T-7121-A)
M5OD-R2
COUNTERSHAFT REAR BEARING REPLACER
308-097 (T85T-7011-A)
FRONT RETAINER SEAL REPLACER
308-105 (T85T-7137-A)
Clutch
PIOLET BEARING REPLACER
308-101 (T85T-70522-A)
Manual trans and hydraulic clutch 1985 thru latest production
Hydraulic Line Disconnect Tool
308-106 (T85T-7140-A)
M5
REVERSE IDLE GEAR SHAFT REMOVER
204-S089 (T85T-5638-A1,A2,A3)
Forged I-beam
FRONT SUSPENSION PIVOT BUSHING TOOL
T83L-19000-A
Crown Victoria/Grand Marquis, Town Car, Ranger, F-Super Duty 650-750, F-Super Duty 250-550, Explorer/Mountaineer/Sport Trac, E-Series AIR CONDITIONING SERVICE KIT
412-035 (T83P-19990-B)
Damaged Evaporator Core Orifice Remover/Extractor (Called out in TSB 06-17-2)
T83P-19623-A
SPANNER WRENCH
T83P-19703-B
LIQUID LINE FLUSHING ADAPTER
T83P-19623-B
COMPRESSOR TEST FITTINGS
TKIT-1983-D2.2
2.2L Diesel Kit
T83T-6306-A
WATER PUMP HUB REMOVER
T83T-6316-C
CRANK DAMPER AND GEAR REPLACER
T83T-6513-B
VALVE SPRING COMPRESSOR BAR
T83T-6019-A
FRONT SEAL REPLACER AND COVER ALIGNER
T83T-6701-C
REAR OIL SEAL INSTALLER
T83T-6316-D
DAMPER REMOVER SPANNER
T83T-9527-B
NOZZLE SEAT CLEANER
TKIT-1982-F
Crown Victoria/Grand Marquis, Town Car, Low Cab Forward, F-150, F-Super Duty 250-550, E-Series
303-177 (T82L-6500-A)
3.0L 2V Vulcan, 3.0L V6, 3.8L, 5.0L, 5.8L
Tappet Bleed Wrench/Collapser
204-071 (T82P-5310-A)
COIL SPRING COMPRESSOR
303-175 (T82L-6316-A)
3.0L 2V Vulcan, 3.2L SHO, 3.4L SHO, 3.8L, 3.8L SC
Crankshaft Vibration Damper Installer
303-176 (T82L-6316-B)
3.0L 2V Vulcan, 3.8L, 3.8L SC, 4.2L, 5.0L
Crankshaft Vibration Damper Remover
T82P-7006-B
ATX TRANSMISSION TEST PLATE
307-126 (T82P-7006-C)
Universal
TEST PLATE MOUNTING SCREWS
T82L-12270-A
DISTRIBUTOR WRENCH
TKIT-1982-FH
Mustang
308-080 (T82T-7003-CH)
M5OD-R1, M5OD-R2
LOCKNUT WRENCH ADPT
T82T-7003-BH
PRESS FRAMER ADAPTER
T82T-3006-AH
TWIN I- BEAM PIVOT BUSHING SPACER
T82T-3504-BH
LOCKNUT WRENCH ADPT
T82T-3504-AH1
T82T-3504-AH2
GUIDE
T82T-4016-AH
AXLE TUBE SEAL REPLACER
308-081 (T82T-7003-DH)
T5OD
MAINSHAFT FRONT BEARING REPLACER
T82T-4204-AH
POWER-LOCK CHECKING TOOL
T79L-50-EEC-II
1979 ELECTRONIC ENGINE CONTROL SYSTEM TESTER
T74P-6000-L
Ranger, Fusion/Milan/MKZ, Focus, F-Super Duty 250-550, Escape/Mariner/Hybrid LIMA OHC ENGINE SERVICE KIT
303-108 (T74P-6700-B)
2.3L OHC, 2.5L OHC
Crankshaft Front Oil Seal Remover
303-103 (T74P-6375-A)
Universal
Flywheel Holding Tool
T74P-7137-H
T74P-9487-A
303-094 (T74P-6019-B)
2.3L OHC
Front Cover Aligner
303-099 (T74P-6306-A)
2.3L OHC
Crankshaft Timing Pulley Installer/Remover
T74P-6015-A
303-096 (T74P-6150-A)
2.0L, 2.3L OHC, 2.5L, 2.5L OHC
Cam and auxiliary shaft seal replacer
T74P-9510-A
John Smith
about some of these tools
do you still have the following?..
2.3L OHC
Front Cover Aligner
2.3L OHC
I really only need these..particularly the 303-099 are they a part of a set?...and price?
HC_Tad
IA
2.3L OHC
Front Cover Aligner
2.3L OHC
Sorry, I don't that kit anymore. Next week I'll try to take inventory again so everyone knows what I have.
