Fore hat fuel sender?
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
Hey guys need some help figuring out exactly which fuel level sender I need for my fore hat.... The hat is for a 2010 car but mine is a 2005 I ordered a level sender for a 2010 gt thinking that was the correct one but it doesn't seem to look that way now that I have received it.
Here are some pics of my hat that I have
Wicked97
Beltsville, MD
the sender should be 2 pieces you need to take it apart and the small part should slide in
thats how it works for 08-09 2010 is a goofy year though
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
I know on my 2010 it could only be used for that year, it did not work correctly on an 05-09 car.
Back@itagain
Southeastern, MI
^^^^^this. Works just fine in my 05. Pinch the arrow shaped end and push it back out of the larger plastic assembly. Then insert into the Fore fuel hat.
Edit...this is a newer sending unit. Not the original out of the 05's
TurboX
Formally Buzz Lightyear
San Anto,Tejas
Like said above, you must push the arrow to get it out of plastic housing. If you have a 2010 sender, it should work just like it did when that hat was in my car.
