FR (9.8:1) Aluminator SB
Chris is good people. I'll take his word for it.
Cobra SS
I just remember what psfracer said about running 9.8:1 cr on pump. See post #13.
"I wouldn't go any higher then 13psi with 9.8 compression if you insist on running pump gas. 18psi with that compression your going to either rattle the thing to death or have to run such low timing that it won't make any sense"
http://www.s197forum.com/forum/showthread.php?t=41559
cruzing2much
hammonton,nj
wow,
"at 19lbs of boost i was running it on pump gas at 724rwhp"
see post #43,
http://www.modularfords.com/forums/showthread.php/167445-ford-3v-Aluminator-short-block/page6
I'm glad to see this is what your up to on thanksgiving. i was just stating that at that compresion ratio thats what the car dynoed at when i had a stick tranny in it. clutch didn't last long and went to an auto then cranked it up from there. car now runs on c16 full time as it dosen't see street duty anymore. You can try to start what ever you want nothing to hide.
Cobra SS
19psi,9.8:1cr,pump gas and 724rwhp, I need to dump the Whipple and get a Procharger
