Front Sway bar removed test.
1fastpony
This was just an experiment last Saturday at the track. It was HOT AS HELL.
How many folks run without the front sway bar and no anti squat brackets? Are anti squat brackets needed with front sway bar removed? The car doesn’t 60’ well, lot of squatting when removed. 1-3 shift the car bucks like an old horse buggy…this aint good. Couple of times it seemed the rear axle hit. Once during launch and the other 1-2 shift.
Have D-specs set at ~ -3-4 turns.
dysan
Dis-Member
Williamstown, N.J.
I'm currently set-up that way but I do think I need the relo/anti squat brackets. My car squats real hard and I know it's hitting the bump stops. The best 60' I've been able to muster is a 1.77 and I'm still on stock springs and shocks that have 117k miles on them.
I don't get the "bucking" your talking about though.
1fastpony
The “Bucking” is from the initial launch and each gear shift. I figured the aftermarket springs and shocks would prevent some of this issue. Had this problem with the stock suspension until installing anti squats which helped change the instant center. The street never have this problem due to no traction. Maybe this Wednesday night at KOH I will try it again with the LCA’s in the lower position. I’m not one to set up the suspension real soft. Too much car movement waste energy in the car going forward. I did confirm that the steel braided hydraulic line for the clutch help with shifting with the new clutch. Tranny never binded up like it use to when the car suspension was too lose.
I’m thinking if I can get the front of the car up from launch 6-8 inches and carry that momentum forward through second and into third with the front end up will not just help my 60’ but also 1/8. With the sway bar on and d-specs set accordingly, the car would raise up 4-6 inches out of the hole and then dropped down after 2nd gear and would spin some through second gear, just enuff to give up some time.
19COBRA93
Ford Racing
Clinton, Ut
You need to stiffen up those D-specs if you're getting bucking. And if you're getting a lot of weight transfer which it sounds like you are, then unhooking the sway bar isn't going to help. These cars dead stock weight transfer really well, so unless you're ditching the sway bar for the weight savings alone, then there's really no point.
Tighten up those D-specs and the "bucking" will mellow out.
1fastpony
you are confirming my thinking, thanks. Lower the anti squats, tighten up the front d-specs to to 2-3 turns. I think when I spray it I'll need the front even more stiff.
Simon
Tighten the rear to full hard or one turn out
Front full loose or 7 out.
Sway bar unhooked.
1.70 60'
Ride the clutch just slightly out of the hole and then side step it.
1fastpony
Sway bar unhooked.
1.70 60'
with or without AS brackets or, does'nt matter?
Simon
I'm not sure what AS brackets are.
At the track, my rear suspension is:
D-Specs (full hard or one turn out)
Eibach pros
BMR LCA relocate brackets (lowest hole)
Steeda LCAs
OEM UCA
MT ET street 26x11.5x17 bias ply tires.
Front
D-Specs (7 turns out)
Front sway bar unhooked
Eibach pro
I would like to get 15x10 in the back with skinnies just to see what would change.
rojizostang
i love my cams
san antonio, texas
MattD started a good thread about sixty foot times, you should be able to find it with a search
here it is
http://s197forum.com/forum/showthread.php?t=32593
on mine:
pro kit
d specs all the way loose in the front
5 turns out in the back
17" skinnies
17x11x26.5 et streets bias ply
no front sway bar
4.56 gear
relocation brackets bottom hole
no passenger seat
1/4 tank of gas
4.5k clutch dump
steeda adj lca's
j&m uca
j&m adj panhard
msd 2 step
consistent 1.67-1.69 60' times (with a good burn out, pulling right up to the line with no dry hop)
qwikhuh
here it is
on mine:
pro kit
17" skinnies
no front sway bar
4.56 gear
no passenger seat
1/4 tank of gas
4.5k clutch dump
steeda adj lca's
j&m uca
j&m adj panhard
msd 2 step
4:56s with a 26.5 in tire? What rpm are you going through the traps at?
1fastpony
here it is
on mine:
pro kit
17" skinnies
no front sway bar
4.56 gear
no passenger seat
1/4 tank of gas
4.5k clutch dump
steeda adj lca's
j&m uca
j&m adj panhard
msd 2 step
Oh yeah. Hows San Anton doing? I need to get the family back over there. Got some relatives there and in the hil country. Love those roads for the stang.
jroc07gt
its orange not yellow!!
hammond,la
dont you remember watching my car was do this at the track? then next time when i had full suspension it was all gone and i dropped 3 tenths of my time. dont forget that when you move your lca's you have to recheck your pinion angle.
1fastpony
Yep I remember. Trying to get the car to hook better if can. Running some where between 1.5 to 2 degrees negative normal settings so lowering them gets me into the -4 range. Going back tonight with my settings with the sway bar removed and see. It seems to work on the street with the lca's lowered. the car just wants to dig in from a dig.
There is a TnT at Gulfport with that scrappin the coast event.
