TonyN
Ford Junkie
I've watched your video probably a dozen times at least. You can accuse me of being biased if you like, but I'm being logical. LOOK at the movement! ANY movement would be at the BOTTOM of the injector where there's no fuel pressure. NONE! Thinking this will cause a fuel leak is REDICULOUS! It's that simple.
Unbolt your fuel rail and rock it back and forth. You'll see for your self that all the movement will be at the bottom of the injector, not the top. It's not rocket science.
How about vacuum leaks then from the bottom injector o-rings when they wear due to the movement?
and shut the hell up...LMAO!!
