FS: Cylinder Compression Tool
2k05gt
Manassas, VA
I made several on these fittings to do a Valve Spring Swap, they worked flawlessly, I tightened the fitting into the Spark Plug Hole, connected an air Hose and went to town replacing springs. :beer:
No worries, 90 PSI kept the Valves in place while I replaced the Springs.
$15.00 Shipped.
I have 2 of the full size fittings ( these allows for a better seal when tightened)
ALL Threads are sealed with JB Weld to ensure they do not come loose (Also the Spark Plug casing is threaded to the pipe)
I tried to undo a test unit in a vise using a long bar, using my weight on it and the threads never let loose. "I twisted the brass pipe" but the threads never budged.
the third one will allow you to use your own fittings and air hose
$10.00 Shipped
2k05gt
Manassas, VA
Will a compression regular compression tester screw into these?
Yes, the air fitting threads are standard. These are used to keep your cylinder under high pressure so your Valves don't fall into the cylinder while replacing the springs, But I guess you can use it for that as well.
5.0 Junkie
Lees Summit, MO
pm me your paypal address and I'll take the top one.
