Fuel Sytem Wire Harness for Return style setup
This harness is designed for guys converting to a return style fuel system and bypassing the fpdm(s) and oem harness. The kit is a combination of my fuel system upgrade kit which supplies power right from the battery via a relay and the additional power/ground harness's needed to run the pumps full on in a return configuration.
Kit start at $60 shipped in the cont us for a standard dual pump setup, but again I can build these custom to your setup/needs.
Kit Features:
-All 10 gauge wiring throughout to minimize amp pull of the pump(s)
-Automotive relay(s) and blade style fuse holder(s)
-All connections soldered or crimped and heat shrinked
-Comes with all necessary connectors and hardware for a clean and easy install.
Here are some shots of kits I have already built for forum members.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
This kit from Jeremy is top notch! He helped me save a butt load of money over the competitors harnesses chiming in at 150$-175$. He even went as far as to custom tailor the harness to my remote mounted battery. The connections are all quality and shrink wrapped. He provides extra connections and shrink wrap in the kit to complete the job in a professional manor. As soon as the opportunity presents itself I will post ample pictures of the kit and the install. He truly took care of me. Hopefully Jeremy will release his full return style fuel system soon so that the average Joe, like myself, can afford to provide the best fuel system available IMHO for our vehicles. I'm sure all who have converted know how expensive supporting mods can be when searching for solid numbers. Jeremy has totally revolutionized this industry with all that he offers so that the "common" man can afford to go fast.
Pictures to fallow.
Didnt know anyone was waiting. lol I can get all the parts anytime. It would be a diy setup where you ran your lines and fittings as you want.
JoshK
Modder AKA Fuel
Nebraska
Pictures to fallow.
Was just following up on this. Would just like to know what a full setup like this would run. Not really ready to pull the triger on it just yet, but have been window shopping...
