This harness is designed for guys converting to a return style fuel system and bypassing the fpdm(s) and oem harness. The kit is a combination of my fuel system upgrade kit which supplies power right from the battery via a relay and the additional power/ground harness's needed to run the pumps full on in a return configuration.
Kit start at $60 shipped in the cont us for a standard dual pump setup, but again I can build these custom to your setup/needs.
Kit Features:
-All 10 gauge wiring throughout to minimize amp pull of the pump(s)
-Automotive relay(s) and blade style fuse holder(s)
-All connections soldered or crimped and heat shrinked
-Comes with all necessary connectors and hardware for a clean and easy install.
Here are some shots of kits I have already built for forum members.
Kit Features:
