Fuel's Winter Project: Build It Before It Blows
jodadejss06gt
TEAM DELETE SHIT
Severn MD
Just finally read over the whole thread.....Congrats.
I know others have mentioned suspension mods etc., but I put on Steeda Ultra Lites, Koni Str.t Shocks and Struts, LCAs and a PHB and have pulled 1.49x 60's on 17" bullitts with ET streets. Not a bad setup for lowering and great everyday street driving. You could still rip around town and take turns really hard with that setup too.
Also, something to think about....you may be switching out your rear gears as the 1st gear in the 6060 is much taller. I have the 2.66 1st in my Magnum and with 3.55(stocker) its not that great for first gear. I'm considering either 3.73 or 4.10. Just something to keep in the back of your mind. When I get into boost in 1st though, it is really fun. It will full boost also.
JoshK
Modder AKA Fuel
Nebraska
mikeyfitz style update
I sold my MBRP A/B today, so now which exhaust do I go with, dumps, mid mount resonators, dynomax 3" catback?
In all seriousness, I did sell the MBRPs, and have a 44mm wg incoming. The new turbo kit should have gotten to Bobby@S&H today also for a fresh coating. I will order the BMR K member in a week or so and hopefully be puting the turbo back on the car soon. Then it is on to the suspension mods since i will finally be able to lower this car!
Edit.
Just spoke with bobby and my kit is already being blasted. Should have it in about a week with a fresh coating on it.
JoshK
Modder AKA Fuel
Nebraska
I have no complaints with the cams at all, great driveability and good power.
Weatherman, I think we should be asking about your car being done. You are much closer than me.
JoshK
Modder AKA Fuel
Nebraska
Car sitting on jackstands again patiently waiting on parts to arrive. Should have the hotside back from Bobby@S&H after a fresh coating late this week or early next week. Then the bmr a arms and k member. I will probably go ahead and install all of that along with the turbo kit before moving forward with any other mods.
weather man
Persistence Is A Bitch
MN
Sweet! Hmmmm Using a GT500 pump setup. :) Maybe I could learn something from a young buck!
JoshK
Modder AKA Fuel
Nebraska
Yep, GT500 pump kit with a kb dual bap. Even though it was a saleen speedlab dual pump kit, so i ended up rewiring most of it for the larger power wire and bap. Pretty easy if you sit down and stare at it for awhile.
JoshK
Modder AKA Fuel
Nebraska
Stock heads with trickflow valve springs, lockouts, and a set of custom grind comp cams. The specs are posted a few pages back.
The fuel pumps are still stock Gt500 pumps. I do have a -8 fuel line from the hat to the fuel rail though
JoshK
Modder AKA Fuel
Nebraska
All the piping is here! Much straighter layout with all 3" piping instead of the on3 setup.
JoshK
Modder AKA Fuel
Nebraska
It is one eyed willy's homemade kit. He decided to go with a different kit to get his car so that he can run a stock fan setup again.
JoshK
Modder AKA Fuel
Nebraska
American Muscle is now carrying the Airlift Digital Kit! With the discount code this is the cheapest I have seen it anywhere. This is making it very hard to stop spending money on my car!
Air Lift Suspension Kit - Digital (05-14 All)
100370
OUR PRICE $3,078.99(kit)
mustangtuning_2268_1914509
